Why is 1 not enough? What are you intending to order from the carriers!?!?
Browse Forums Building A New House Re: Building with Metricon 7061Apr 27, 2018 2:56 pm NthHome Top for all : when doing electrical appt make sure you get two conduits installed from the power pole...... allow for Foxtel , Telstra and Optus .....one is not enough! Why is 1 not enough? What are you intending to order from the carriers!?!? Re: Building with Metricon 7062Apr 27, 2018 3:16 pm george27 NthHome Top for all : when doing electrical appt make sure you get two conduits installed from the power pole...... allow for Foxtel , Telstra and Optus .....one is not enough! Why is 1 not enough? What are you intending to order from the carriers!?!? If you want a phone line plus CABLE internet then you need two... they can’t be installed in the same conduit. Gets worse if Foxtel is installed via cable ..... Re: Building with Metricon 7063Apr 27, 2018 3:33 pm NthHome george27 NthHome Top for all : when doing electrical appt make sure you get two conduits installed from the power pole...... allow for Foxtel , Telstra and Optus .....one is not enough! Why is 1 not enough? What are you intending to order from the carriers!?!? If you want a phone line plus CABLE internet then you need two... they can’t be installed in the same conduit. Incorrect, I've done both in the same conduit. Re: Building with Metricon 7064Apr 27, 2018 3:47 pm george27 NthHome george27 [quote="NthHome"]Top for all : when doing electrical appt make sure you get two conduits installed from the power pole...... allow for Foxtel , Telstra and Optus .....one is not enough! Why is 1 not enough? What are you intending to order from the carriers!?!? If you want a phone line plus CABLE internet then you need two... they can’t be installed in the same conduit. Incorrect, I've done both in the same conduit.[/quote] You are lucky then! Ive spent the last 5 months arguing with telstra about this .... I still don’t have a phone line. Everyone technician I’ve spoken insist phone line can not be in the same conduit. Re: Building with Metricon 7065Apr 27, 2018 5:50 pm The telecommunications standard is that the services must be separated. That being said, it comes down to the the liney doing the installation Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 7066Apr 27, 2018 6:52 pm Drew01 The telecommunications standard is that the services must be separated. That being said, it comes down to the the liney doing the installation I’ve had three different people ( don’t go there ) and all said they must be separate Re: Building with Metricon 7067Apr 27, 2018 10:00 pm NthHome Drew01 The telecommunications standard is that the services must be separated. That being said, it comes down to the the liney doing the installation I’ve had three different people ( don’t go there ) and all said they must be separate So if we’ve got M to put sockets for phone line, Foxtel/cable and NBN, does that mean they will have the right number of conduit to the power pole or are they separate issues? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Building with Metricon 7068Apr 27, 2018 11:30 pm Quirmeball1280 NthHome Drew01 The telecommunications standard is that the services must be separated. That being said, it comes down to the the liney doing the installation I’ve had three different people ( don’t go there ) and all said they must be separate So if we’ve got M to put sockets for phone line, Foxtel/cable and NBN, does that mean they will have the right number of conduit to the power pole or are they separate issues? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Nup I got the same and only got one conduit ... Re: Building with Metricon 7069Apr 27, 2018 11:57 pm We've had a conduit run in at our place, but it's not big enough for HFC, and I've got no idea where it goes, as we've got no telco pit on our side of the street... will deal with it when I have to Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 7070Apr 28, 2018 9:13 pm Special_K NthHome Top for all : when doing electrical appt make sure you get two conduits installed from the power pole...... allow for Foxtel , Telstra and Optus .....one is not enough! Re: Building with Metricon 7072Apr 29, 2018 12:26 am I thought that too above mine. But once the sinks are in it’s not too bad Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?t=86597 Re: Building with Metricon 7073Apr 29, 2018 7:26 am Doulton777 I thought that too above mine. But once the sinks are in it’s not too bad Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?t=86597 What’s your vanity height Doulton? Re: Building with Metricon 7074Apr 29, 2018 10:44 am emmyawards Doulton777 I thought that too above mine. But once the sinks are in it’s not too bad Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?t=86597 What’s your vanity height Doulton? The vanity is 770mm viewtopic.php?t=86597 Re: Building with Metricon 7075Apr 29, 2018 10:56 am We lifted all our vanity benchtops to 870mm as we felt 770mm was far too low. This will put the top of our semi insert sinks at 930mm. We don't care about future owners and their view on the sink heights, we're worried about us having to live with it for 20 years We had to agree 3 times that we wouldn't come back at Metricon for them not being at 770mm. I measured in 4 display homes and they were all between 860 and 900 depending on the sink Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 7076Apr 29, 2018 11:53 am Drew01 We lifted all our vanity benchtops to 870mm as we felt 770mm was far too low. This will put the top of our semi insert sinks at 930mm. We don't care about future owners and their view on the sink heights, we're worried about us having to live with it for 20 years We had to agree 3 times that we wouldn't come back at Metricon for them not being at 770mm. I measured in 4 display homes and they were all between 860 and 900 depending on the sink Re: Building with Metricon 7077Apr 29, 2018 11:59 am Renman Drew01 We lifted all our vanity benchtops to 870mm as we felt 770mm was far too low. This will put the top of our semi insert sinks at 930mm. We don't care about future owners and their view on the sink heights, we're worried about us having to live with it for 20 years We had to agree 3 times that we wouldn't come back at Metricon for them not being at 770mm. I measured in 4 display homes and they were all between 860 and 900 depending on the sink I’m 166.5 it seemed ok when I went closer to it. viewtopic.php?t=86597 Re: Building with Metricon 7078Apr 29, 2018 1:37 pm I'm 5'11" and my wife is 5'9" ... Our current bathroom counter is 900, so 870 was a compromise Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Building with Metricon 7079Apr 29, 2018 4:26 pm Our vanities are at 865mm and our Axa H10 above counter basins will add 100mm to that height Also, the measurements are usually from base floor height, i.e before your tiles are fitted. While you are thinking about vanity heights, also consider the height of your light switches and whether they will be horizontal or vertical Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Building with Metricon 7080Apr 29, 2018 4:58 pm Quirmeball1280 Our vanities are at 865mm and our Axa H10 above counter basins will add 100mm to that height Also, the measurements are usually from base floor height, i.e before your tiles are fitted. While you are thinking about vanity heights, also consider the height of your light switches and whether they will be horizontal or vertical Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10759 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8205 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17335 |
