Browse Forums Building A New House Re: Building with Metricon 8563Mar 07, 2020 6:44 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building with Metricon 8565Mar 08, 2020 7:42 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building with Metricon 8567Mar 08, 2020 12:50 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building with Metricon 8570Mar 30, 2020 9:07 pm Drew01 What cooling system do you have, and what was the guy there for? We have Braemar. We called the cooler company to check why it is not cooling and breeze seems to be quite weak even we turn on high. They couldn't find anything wrong with it. Re: Building with Metricon 8571Apr 22, 2020 8:53 am We have this very annoying humming noise coming from the ceiling of our Master bedroom ensuite and the bedroom next to it. The constant humming noise is audible through the whole night till early morning. Around 7am to 8am, there will be a loud banging noise also coming from the ceiling then the humming noise will stop. At first we thought the banging noise was from the construction behind our house but after checking it, it was from inside the house and from the ceiling. We suspected the humming noise is coming from the water heater due to the antifreeze valve but not sure about the banging sound. My daughter has to shift to another bedroom due to the humming noise. It is really very disturbing. Wondering anyone has this problem and how to solve it. Thanks in advance. Re: Building with Metricon 8572Apr 25, 2020 10:23 pm Kimmykim We have this very annoying humming noise coming from the ceiling of our Master bedroom ensuite and the bedroom next to it. The constant humming noise is audible through the whole night till early morning. Around 7am to 8am, there will be a loud banging noise also coming from the ceiling then the humming noise will stop. At first we thought the banging noise was from the construction behind our house but after checking it, it was from inside the house and from the ceiling. We suspected the humming noise is coming from the water heater due to the antifreeze valve but not sure about the banging sound. My daughter has to shift to another bedroom due to the humming noise. It is really very disturbing. Wondering anyone has this problem and how to solve it. Thanks in advance. We have the dripping noise above our master bedroom, which is the hot water system. Until your post I hadn't thought much about it but we do get a random thumping in that wall too, usually in the morning. It's the external wall so it doesn't affect any room but ours. Re: Building with Metricon 8573May 01, 2020 11:13 pm Does anyone have an Actron refrigerated cooling/heating unit? Can you help?? We have just restored the factory settings as it was doing some strange things (probably as a result of me playing around with it when we first moved in)... anyway, since I did this today when the unit is in heating mode and set at 22°C, the main control unit gradually starts dropping in temperature by half a degree until it has gone down at least 2 or 3°C. This in turn drags down the zone temperature for the lower floor to then be lower than it was originally set at. It seems that the zone temperature cannot be any more than 2°C different to the main control unit temperature. We are wondering why the main control unit keeps dropping its set temperature automatically over the course of 30 minutes or so... help!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Metricon 8574May 02, 2020 2:35 pm shokel1975 Does anyone have an Actron refrigerated cooling/heating unit? Can you help?? We have just restored the factory settings as it was doing some strange things (probably as a result of me playing around with it when we first moved in)... anyway, since I did this today when the unit is in heating mode and set at 22°C, the main control unit gradually starts dropping in temperature by half a degree until it has gone down at least 2 or 3°C. This in turn drags down the zone temperature for the lower floor to then be lower than it was originally set at. It seems that the zone temperature cannot be any more than 2°C different to the main control unit temperature. We are wondering why the main control unit keeps dropping its set temperature automatically over the course of 30 minutes or so... help!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ you really should contact actron air directly via their website Re: Building with Metricon 8575May 02, 2020 3:05 pm [quote="FortuneCat":1akywgmd][quote="shokel1975":1akywgmd]Does anyone have an Actron refrigerated cooling/heating unit? Can you help?? We have just restored the factory settings as it was doing some strange things (probably as a result of me playing around with it when we first moved in)... anyway, since I did this today when the unit is in heating mode and set at 22°C, the main control unit gradually starts dropping in temperature by half a degree until it has gone down at least 2 or 3°C. This in turn drags down the zone temperature for the lower floor to then be lower than it was originally set at. It seems that the zone temperature cannot be any more than 2°C different to the main control unit temperature. We are wondering why the main control unit keeps dropping its set temperature automatically over the course of 30 minutes or so... help!!! [img:1akywgmd]https://forum.homeone.com.au/u/83269_1588338806.jpeg[/img:1akywgmd][/quote:1akywgmd] you really should contact actron air directly via their website[/quote:1akywgmd] Only been in house 5 months, so will be contacting M to send someone out.... Just been avoiding that – as they are a pain in the backside to deal with for warranty and service. Re: Building with Metricon 8577May 02, 2020 4:35 pm Jayjay84 Is ur system set on auto? My old actrom one was and it would change itself every half hour or so Yes it is... maybe I will try taking it off auto. I also think it may be happening when upstairs is not on and is too cold up there. Thanks 😊 Re: Building with Metricon 8578May 02, 2020 8:28 pm blackcat20 Kimmykim We have this very annoying humming noise coming from the ceiling of our Master bedroom ensuite and the bedroom next to it. The constant humming noise is audible through the whole night till early morning. Around 7am to 8am, there will be a loud banging noise also coming from the ceiling then the humming noise will stop. At first we thought the banging noise was from the construction behind our house but after checking it, it was from inside the house and from the ceiling. We suspected the humming noise is coming from the water heater due to the antifreeze valve but not sure about the banging sound. My daughter has to shift to another bedroom due to the humming noise. It is really very disturbing. Wondering anyone has this problem and how to solve it. Thanks in advance. We have the dripping noise above our master bedroom, which is the hot water system. Until your post I hadn't thought much about it but we do get a random thumping in that wall too, usually in the morning. It's the external wall so it doesn't affect any room but ours. We also have the dripping noise above the ensuite. Anyway, we have contacted M to get Chromagen to come in next week. See what they have to say. Re: Building with Metricon 8579May 30, 2020 9:31 pm Hi, anyone knows whether we’ll have neutral wire in lighting switch or not? Also do anyone knows about registering positive covenant for OSD? Thanks Metricon - Liberty 38 with Provincial facade - Ryde https://forum.homeone.com.au/viewtopic. ... &p=1859996 Re: Building with Metricon 8580May 30, 2020 10:30 pm Phoenix77 Hi, anyone knows whether we’ll have neutral wire in lighting switch or not? Also do anyone knows about registering positive covenant for OSD? Thanks I'm not a sparky, but still think there is red, black and green in the wiring In regards to the positive covenant, a registered surveyor should help you there, but why could your builder not tell you that? Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10749 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8200 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17331 |
