Browse Forums Building A New House Re: Building with Metricon 6167Sep 21, 2017 9:18 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Building with Metricon 6168Sep 21, 2017 9:47 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Building with Metricon 6169Sep 21, 2017 9:56 pm Doulton777 They will usually use left over from the batch. They order more cos porcelain is harder too install and cracks easier. They usually need to make sure they get it right to begin with. Cos with porcelain they crack easier when you remove one. More can end up cracking. viewtopic.php?t=86597 I thought ceramic tiles were the ones that are harder to install since they're not vitrified and therefore they crack easier as they lack density. Because of their lower cost, manufacturing tolerances are looser and so they're harder to lay as the edges aren't always straight. Porcelain tiles are vitrified and therefore more hard wearing and made to a better tolerance and thus easier to get a better edge or thinner grout line. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Building with Metricon 6170Sep 22, 2017 1:29 am nomnomnom Doulton777 Hubby just rang the stair place apparently that's what they use for all the stairs unless you upgrade like the display. Gosh even the wood there is upgrading. We weren't even told that. It's pretty expensive he said. Plus it takes a very long time. On the other hand. We bought off the plan. If we had the tour I guess we would have been told these things. viewtopic.php?t=86597 Yes MDF is standard. Depending on the level of home, M will give you the bottom two stair treads as Maple, but the risers will be white painted MDF. I'm doing carpet on stairs post handover. Im also doing spotted gum hardwood timber flooring post handover too. You might be interested to hear that the floor installers can lay your flooring timber over the mdf stairs if you like which is quite a bit cheaper than upgrading your stairs. For example I think a staircase upgrade is about $20k if it's one of those nice looking cantilevered ones with glass and steel balustrade and no risers. Yes thanks we spoken to them about that. I don't think it makes a difference to us. I think we have that here now with our stairs. It seems good enough. We are not going to spend that much for something you won't even see anyway as it will be covered by carpet. We have spotted gum flooring now. It's one of the nicest I reckon. So it's a good choice. viewtopic.php?t=86597 Re: Building with Metricon 6171Sep 22, 2017 1:32 am nomnomnom Doulton777 They will usually use left over from the batch. They order more cos porcelain is harder too install and cracks easier. They usually need to make sure they get it right to begin with. Cos with porcelain they crack easier when you remove one. More can end up cracking. viewtopic.php?t=86597 I thought ceramic tiles were the ones that are harder to install since they're not vitrified and therefore they crack easier as they lack density. Because of their lower cost, manufacturing tolerances are looser and so they're harder to lay as the edges aren't always straight. Porcelain tiles are vitrified and therefore more hard wearing and made to a better tolerance and thus easier to get a better edge or thinner grout line. No definitely the porcelains are more sensitive. That's one reason why tilers hate laying them. Plus they charge a fortune for laying them. Once you remove one. More are likely too break. That's the worst thing about them. viewtopic.php?t=86597 Re: Building with Metricon 6172Sep 22, 2017 3:56 am Doulton777 nomnomnom Doulton777 They will usually use left over from the batch. They order more cos porcelain is harder too install and cracks easier. They usually need to make sure they get it right to begin with. Cos with porcelain they crack easier when you remove one. More can end up cracking. viewtopic.php?t=86597 I thought ceramic tiles were the ones that are harder to install since they're not vitrified and therefore they crack easier as they lack density. Because of their lower cost, manufacturing tolerances are looser and so they're harder to lay as the edges aren't always straight. Porcelain tiles are vitrified and therefore more hard wearing and made to a better tolerance and thus easier to get a better edge or thinner grout line. No definitely the porcelains are more sensitive. That's one reason why tilers hate laying them. Plus they charge a fortune for laying them. Once you remove one. More are likely too break. That's the worst thing about them. viewtopic.php?t=86597 I see, I just thought they cost more to lay cause my the tiler wanted to rip me off even more! hehe. Thanks for the info, I put all porcelains on my wet area floor as I thought denser is better but one or two might need to be redone so that will be interesting. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Building with Metricon 6173Sep 22, 2017 7:01 am Doulton777 We have spotted gum flooring now. It's one of the nicest I reckon. So it's a good choice. We went with Spotted Gum engineered hardwood with M, as they were about $12k cheaper than one of my mates who is on the industry. We love the colours in it vs the laminate flooring equivalent that if you see a box laid you can pick the repeat in the printing of the grain pattern Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 6174Sep 22, 2017 10:24 am Drew01 Doulton777 We have spotted gum flooring now. It's one of the nicest I reckon. So it's a good choice. We went with Spotted Gum engineered hardwood with M, as they were about $12k cheaper than one of my mates who is on the industry. We love the colours in it vs the laminate flooring equivalent that if you see a box laid you can pick the repeat in the printing of the grain pattern That is the exact opposite experience I have had with M for flooring. Congrats on the saving, that's good. I am able to install genuine hardwood spotted gum select grade for the same price they quoted me for engineered boards. We love the colours too but only the NSW spotted gum as you get a nicer variety of brown, creams and olives throughout. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Building with Metricon 6175Sep 22, 2017 10:45 am nomnomnom Drew01 Doulton777 We have spotted gum flooring now. It's one of the nicest I reckon. So it's a good choice. We went with Spotted Gum engineered hardwood with M, as they were about $12k cheaper than one of my mates who is on the industry. We love the colours in it vs the laminate flooring equivalent that if you see a box laid you can pick the repeat in the printing of the grain pattern That is the exact opposite experience I have had with M for flooring. Congrats on the saving, that's good. I am able to install genuine hardwood spotted gum select grade for the same price they quoted me for engineered boards. We love the colours too but only the NSW spotted gum as you get a nicer variety of brown, creams and olives throughout. Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 6176Sep 22, 2017 11:01 am nomnomnom Doulton777 nomnomnom [quote="Doulton777"]They will usually use left over from the batch. They order more cos porcelain is harder too install and cracks easier. They usually need to make sure they get it right to begin with. Cos with porcelain they crack easier when you remove one. More can end up cracking. viewtopic.php?t=86597 I thought ceramic tiles were the ones that are harder to install since they're not vitrified and therefore they crack easier as they lack density. Because of their lower cost, manufacturing tolerances are looser and so they're harder to lay as the edges aren't always straight. Porcelain tiles are vitrified and therefore more hard wearing and made to a better tolerance and thus easier to get a better edge or thinner grout line. No definitely the porcelains are more sensitive. That's one reason why tilers hate laying them. Plus they charge a fortune for laying them. Once you remove one. More are likely too break. That's the worst thing about them. viewtopic.php?t=86597 I see, I just thought they cost more to lay cause my the tiler wanted to rip me off even more! hehe. Thanks for the info, I put all porcelains on my wet area floor as I thought denser is better but one or two might need to be redone so that will be interesting. [/quote] Yeah na every tiler will tell you it's harder too lay more of a headache. As well as the cutting of them and getting them straight. Normal tiles are more easier. viewtopic.php?t=86597 Re: Building with Metricon 6177Sep 22, 2017 11:18 am Drew01 Doulton777 We have spotted gum flooring now. It's one of the nicest I reckon. So it's a good choice. We went with Spotted Gum engineered hardwood with M, as they were about $12k cheaper than one of my mates who is on the industry. We love the colours in it vs the laminate flooring equivalent that if you see a box laid you can pick the repeat in the printing of the grain pattern Yes it's a very nice flooring. You won't regret it. If you decide to do it. Consider the texture you out on it. You can get the Matt look. Or the high gloss. I reckon high gloss makes it looks more classier. There's pros and cons to everything. So research it first. Look at different pic and designs with them all so you know what texture you want. Me personally I don't prefer the Matt look. But it's meant to be tougher and not scratch easy. But the high gloss look. Looks so much better and gives a real nice look too it. But it depends on what your taste is. The Polyurethane – Water-Based is suppose to be more of hard wearing. I have had both. But far for me I prefer the high gloss look. viewtopic.php?t=86597 Re: Building with Metricon 6178Sep 22, 2017 11:20 am Drew01 Doulton777 We have spotted gum flooring now. It's one of the nicest I reckon. So it's a good choice. We went with Spotted Gum engineered hardwood with M, as they were about $12k cheaper than one of my mates who is on the industry. We love the colours in it vs the laminate flooring equivalent that if you see a box laid you can pick the repeat in the printing of the grain pattern Wow m was actually cheaper then someone has? Well that's a change viewtopic.php?t=86597 Re: Building with Metricon 6179Sep 22, 2017 11:36 am We spent over $30,000 with m for our carpet. But we have 335sm. M carpet consultant said he never seen so much carpet lol. I told hubby you know the carpet cost more then our facade. viewtopic.php?t=86597 Re: Building with Metricon 6180Sep 22, 2017 12:20 pm U should have done your carpets post. We saved 8k for the exact same one as M. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10765 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8214 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17335 |
