Browse Forums Building A New House 1 Jun 10, 2015 5:17 pm I'm currently building my first home and am already encountering some problems. The frame is up and they've laid the roof tiles. As the frame is up I decided to do a quick walk around. The walk in pantry is next to the laundry. They've run the piping too far and now the pipe is coming out of the floor into my walk in pantry. Issues: - Piping comes up out of the floor in the walk in pantry where my cupboards and bench top should be - No piping for the trough or washing machine provision in the laundry. Is this a huge disaster? Are my cupboards ruined now? Can someone give me any advice on what other things I should check now to ensure there are no more problems? Re: New build issues (first home) 2Jun 10, 2015 5:32 pm No biggie they will chisel up the slab and move the pipes to the right spot. It's very hard to measure pipes before slab to get them all spot on a lot of houses have to have pipes moved Re: New build issues (first home) 3Jun 10, 2015 5:39 pm At least half of our pipes ended up having to be moved. My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Re: New build issues (first home) 5Jun 10, 2015 5:54 pm I'd recommend you get an independent building inspector to help with these issues, although depending on your state they may or may not be particularly helpful. Where are you building? Jen (& Dave) Plantation Bronte, Ormeau Ridge, Gold Coast QLD 12/03/2015 - Commencement... 26/08/2015 - Handover! viewtopic.php?f=31&t=76446 Re: New build issues (first home) 7Jun 10, 2015 5:56 pm Okay, unfortunately I can't give you much advice then But independent advice is a good idea if you're not sure. Jen (& Dave) Plantation Bronte, Ormeau Ridge, Gold Coast QLD 12/03/2015 - Commencement... 26/08/2015 - Handover! viewtopic.php?f=31&t=76446 Re: New build issues (first home) 8Jun 10, 2015 8:11 pm Yep at least half, one of the two toilets were wrong so the concrete had to be chipped up and the pipe relocated, the laundry was wrong and was easier to put in a false cupboard then fix the concrete, all 3 vanities were wrong and the bath. So that leaves only the kitchen, two showers & one toilet that was correct. My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Re: New build issues (first home) 10Jun 10, 2015 10:51 pm Thanks for letting me know. This will definitely help me look at this more closely. I stopped by my build on the way home and had another quick look. It was already dark by that time but confirmed and picked up some more errors. - pipe in pantry not laundry - drainage pipe is sitting where the washing machine and linen cupboard will be - pipe for ensuite vanity is too far out from wall - fixed glass behind cook top / sink (in place of splashback) is clear instead of translucent On the positive though my bricks have arrived! MnT Yep at least half, one of the two toilets were wrong so the concrete had to be chipped up and the pipe relocated, the laundry was wrong and was easier to put in a false cupboard then fix the concrete, all 3 vanities were wrong and the bath. So that leaves only the kitchen, two showers & one toilet that was correct. Re: New build issues (first home) 11Jun 11, 2015 4:37 pm Should there be an overflow drain in my ensuite floor? I queried this with my builder and he said that there is an overflow in my basin which is why there is no overflow drain on the ensuite floor (other than the drain in the shower). Is this normal? For information my ensuite is only small so there is only a shower, toilet and vanity in there (no bathtub). Re: New build issues (first home) 12Jun 11, 2015 6:14 pm Hmm good question, we have one and our vanity doesn't have an overflow but I don't think that has anything to do with it as I am pretty sure the vanity wasn't chosen when the pipes were done. My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Re: New build issues (first home) 13Jun 11, 2015 6:25 pm It is most likely state-dependent. Perhaps it's not required in your state? Jen (& Dave) Plantation Bronte, Ormeau Ridge, Gold Coast QLD 12/03/2015 - Commencement... 26/08/2015 - Handover! viewtopic.php?f=31&t=76446 Re: New build issues (first home) 16Jun 12, 2015 5:22 pm Can anyone tell me what the code says about light switches above the bathtub? Or where I can go to find out more information? Just trying to find out if this is possible at all (to have the light switch above the tiling above the tub - as pictured)? At the moment the light switch is out near the powder entry. It's a small bathroom so quite limited in options! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New build issues (first home) 17Jun 12, 2015 5:25 pm You can but must be water proof. Clipsal do one. I can't be bothered finding the code but u can't use normal switches if they can be switched on whilst standing in a body of water. But can get around it by using a waterproof switch which is what we did Re: New build issues (first home) 18Jun 12, 2015 6:53 pm MrBee You can but must be water proof. Clipsal do one. I can't be bothered finding the code but u can't use normal switches if they can be switched on whilst standing in a body of water. But can get around it by using a waterproof switch which is what we did Thanks - my builder was telling me it wasn't possible. Would they be saying this cos the waterproof ones are too troublesome? Re: New build issues (first home) 20Jun 13, 2015 3:14 pm s2dttn MrBee You can but must be water proof. Clipsal do one. I can't be bothered finding the code but u can't use normal switches if they can be switched on whilst standing in a body of water. But can get around it by using a waterproof switch which is what we did Thanks - my builder was telling me it wasn't possible. Would they be saying this cos the waterproof ones are too troublesome? I don't think they are troublesome but like above only 1 or 2 gang. What we had to do because we need 6 Gang was put the main lights on the waterproof as you walk in and the IXL on anothe switch next to the shower How many switches do you need on the plate? So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27712 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45801 If you are in Victoria you have a statutory right to your own building inspector regardless of builder's consent. No negotiations are required. However the builder will… 1 2937 |
