Browse Forums Building A New House 1 Jun 06, 2015 7:50 am Yesterday I visited the site for a routine frame inspection and as it happens the frame was good and there will be no significant issues reported however site drainage management is inadequate and could cause foundation problems http://i1321.photobucket.com/albums/u559/brankom10/h2_zps0y1nmwca.png http://i1321.photobucket.com/albums/u559/brankom10/site%20flooding_zpsaklisglm.png Building surveyor that inspected the frame said nothing about the drainage So I had a few firm words with the builder about site drainage management negligence and was assured it would be fixed immediately Building stage inspections are not just about critical point reporting but also about monitoring the build best you can without being there all the time and engaging and guiding owners with owners to be my eyes and ears on the ground. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Frame stage inspection is not just about the frame 2Jun 06, 2015 8:04 am Can you explain the p for site trees I can't see any trees in your picture Re: Frame stage inspection is not just about the frame 3Jun 06, 2015 8:29 am MrBee Can you explain the p for site trees I can't see any trees in your picture Google Earth is an amazing product, I use it often together with Nearmap http://i1321.photobucket.com/albums/u559/brankom10/Untitled_zpsy23txtnm.jpg As you can see large trees were cleared during estate development , hence "P" classification Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Frame stage inspection is not just about the frame 4Jun 06, 2015 9:39 am MrBee Can you explain the p for site trees I can't see any trees in your picture Nor can I see trees referenced...in current photos, geo site report or in the engineering codes (AS2870, 2.1.3)... BTW,I would think a licenced Engineer would have the correct Site clasifications ratings covered Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Frame stage inspection is not just about the frame 6Jun 06, 2015 10:26 am goody59, you didn't type anything. Re: Frame stage inspection is not just about the frame 7Jun 06, 2015 10:41 am building-expert I am sure if I go to archive photos at the state library i will find trees all over victoria, that have since been removed, does that mean it should all be classified as P? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Frame stage inspection is not just about the frame 8Jun 06, 2015 11:53 am tlblhayward goody59, you didn't type anything. Where did it go? Not to worry. I was posting a comment re BE's post. I have already advised my Customer Care person from the volume builders I have engaged of my awareness of this potential issue of site drainage and pooling around slab. I am starting my build very shortly on a H2 site. I have read enough now to make me aware of the numerous issues that may arise with any build. Re: Frame stage inspection is not just about the frame 9Jun 06, 2015 7:09 pm goody59 Post edited You do know when you go to edit a post, there is an option there to delete the post if don't want it. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . This is 100% true. You can not hang anything on steel frames. very frustrating 8 8083 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98780 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5420 |
