Browse Forums Building A New House Re: Building a Permanent Fence with Neighbours Still Buildin 9Jun 03, 2015 9:43 pm You'll probably find in most builders documents that you sign it says stuff about retaining walls and fences etc saying if they damage it there not liable to fix it. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7095 The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17155 Building a fence now will help limit people dumping rubbish and soil on your property. Many houses in suburbia on small lots have fences up before a build. I moved into a… 1 4411 |
