Browse Forums Building A New House 1 Jun 03, 2015 2:13 pm Hi, I have got small block as per below drawing. I will have neighbours on both sides. I am not sure what neighbours will be building. If they both are building double storey (most likely), should I also go with double storey? if I go with single storey what should I consider in the design. Thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Design question - Single storey or Double Storey 2Jun 03, 2015 2:24 pm To get some outside areas for that block you are probably going to have to go Double storey. Shading fromNeighbours is going to be an issue see http://www.anewhouse.com.au/2012/01/winter-sun/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8179 1 4581 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9948 |
