Browse Forums Building A New House 1 May 27, 2015 1:33 pm deposit a land by 14*28 there's 3m wide easement in the rear Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ setback in the front 4m rear setback 3m 28-4-3=21 can i just build house next to easement?I mean can i build a 21m length home in that? or shall i have to setback little be from easement ? is anyone can tell me what's the maximum length for my house?21m or should be less than that?thanks easement setback 2May 27, 2015 1:41 pm 21 metres would be 'safe' , although you could push that out depending on what the easement is for. In my last build we had a Water Corp easement but was allowed to build into it if we added piers. Re: easement setback 5May 27, 2015 10:01 pm You might need to chech the max % of the space on your block you can build on, which is a council requirement. For ex you can only build on 50% area of ur block. If it is more then you will need to seek council approval rather than CDC approval. Re: easement setback 6May 27, 2015 10:57 pm HarryV You might need to chech the max % of the space on your block you can build on, which is a council requirement. For ex you can only build on 50% area of ur block. If it is more then you will need to seek council approval rather than CDC approval. thanks for your remind,i will check that as well Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8333 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3611 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15706 |
