Browse Forums Building A New House 1 May 21, 2015 10:06 pm Whilst compiling our lighting shopping list I discovered Beacon have 40% off the 2nd light promo at the moment - not sure if I should stock up now or if they tend to have better sales closer to end of financial year - does anyone know? Re: Beacon Lighting Sales 2May 22, 2015 7:33 am Hi andii, if you are buying a house lot of lights they will give you a discount anyway which will work out cheaper regardless of whatever sale they have on currently. So if you're intending to get everything, don't worry too much about the sales. Jen (& Dave) Plantation Bronte, Ormeau Ridge, Gold Coast QLD 12/03/2015 - Commencement... 26/08/2015 - Handover! viewtopic.php?f=31&t=76446 Re: Beacon Lighting Sales 3May 22, 2015 12:03 pm They have sales often, it is usually 50% off your second light so I wouldn't rush in at the 40% off. Also Beacon are quite expensive compared to other lighting shops with similar products Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8814 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
