Browse Forums Building A New House 1 May 19, 2015 2:46 pm Hi Guys, any one can help me to get how any builder calculate the area of house example one of the design I look for it mention dimension of garage is 5.5 x 5.5 m which 30.25sqm but builder mention 32.5sqm in while calculating total area. same way when I simply calculate with dimension given in design (also included some common area) + porch there is some difference comes in the calculation, my calculation is showing me 210sqm and builder shows me 226sqm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ click image upload If you know anything I am missing here. Please guide me. Re: Building area Calculation 2May 19, 2015 3:06 pm something to do with counting the external walls. If your spreadsheet is the internal wall sizes there is no area of walls in your calcs. Small footprint in Eliza Ponds, Spearwood WA Re: Building area Calculation 3May 19, 2015 3:22 pm When computing total area, it will generally include all the area taken up by walls. Individual room areas won't include this. Re: Building area Calculation 4May 20, 2015 3:16 am Calculations of building area can also measurements taken from the perimeter of the roof line. Re: Building area Calculation 5May 20, 2015 3:17 am Calculations of building area can also include measurements taken from the perimeter of the roof line. Re: Building area Calculation 6May 20, 2015 9:09 am It may not seem kosher for the builder to be stating room areas including the walls; however, both our local council and also the NSW state rules ("Complying Development") include walls in this calculation. Also be aware that if you're looking at these areas because you're thinking about whether a house is too big for your land due to rules on floor-space vs land area, the calculations can include or exclude certain things which might surprise you (if you've not looked into it much yet). For example, you may be allowed to discount staircases, and you may have to include balconies over a certain height above ground-level but ignore balconies under that height. If this is the sort of thing you're wanting to find out, best to check the rules you'll be building under. Hi, My home construction is complete, and the handover is scheduled next week. However the construction has been delayed and I have raised this to the builder. The… 0 5330 Yes you are correct, unless there are outside works which form part of the contract such as landscaping or driveways, and importantly, the work delayed is on the critical… 1 3535 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16566 |
