Our landscaper has recommended that we cut our site down after handover and apply a membrane to our slab edge to protect it from dampness. The process is also called tanking.
Has anyone else done this after handover?
Browse Forums Building A New House Re: Protecting a slab edge 2Apr 21, 2015 10:24 pm http://www.liquidrubbermelb.com.au/ Have a look at liquid rubber, it sounds like it would work well. Good idea to protect slab edge if you can. I will consider the liquid rubber after handover with my Volume Builder. There a a number of these stockers of this type of product. This one is Coburg Melbourne. Re: Protecting a slab edge 3Apr 22, 2015 7:29 am goody59 http://www.liquidrubbermelb.com.au/ Have a look at liquid rubber, it sounds like it would work well. Good idea to protect slab edge if you can. I will consider the liquid rubber after handover with my Volume Builder. There a a number of these stockers of this type of product. This one is Coburg Melbourne. Thanks goody59. It appears to be a simple exercise yet one that is often overlooked. BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Protecting a slab edge 4May 10, 2015 7:40 pm All booked in to cut our site down by 200mm next week so that we can paint the slab edges from the vapour line up. Should be worth the time given it will protect us against dampness.... BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Protecting a slab edge 6May 11, 2015 6:47 am A few hundred if you do it yourself. BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12878 |
