Browse Forums Building A New House Re: Pavers covering weep holes Is This Normal? 21Apr 30, 2015 1:34 pm Thanks one john . I was starting to stress out about my front render covering them . So I guess I should get concreate mot to cover weep holes . Should all the weep hole be left un covered or can I cover half . Thanks again . Re: Pavers covering weep holes Is This Normal? 22Oct 21, 2019 10:34 am Hi All my weep holes 20 mm above the concret how I can solve this problem my suggestion is full half of the weep with silicon or do another weep above the old one can I hear from you cheers it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7084 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5448 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11180 |
