Browse Forums Building A New House Re: I'm back and ready to build! Slab update 20/07 21Jul 20, 2008 7:54 am Well it took longer than we thought to get the slab laid. Because we had so much fill and were having a piered slab we had to wait 10 days for the piers to cure instead of 2. And then, even though queensland is in drought, we had rain!!! So we got pushed back another couple of days.
Finally we have a slab!! Here are some photos: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We also now have power and the Telstra cable has been run to the house. Our concrete tanks and hstp have been delievered and the area on the ground to be dug to bury them has been marked and approved by us. I hate seeing these and was worried you'd be able to see it from the house and alfresco, but hopefully where they have marked it is far enough towards the garage so I won't see it as much. I will just have to screen it from the road. Also, we changed from a poly tank to a concrete one but someone forgot to mention that to the poly people and now I have a HUGE extra tank on the block. I am sort of hoping they forget about it and we can roll it up the back and try and hide it, as long as they haven't charged me for it that is!! Our frame should be delieverd around the 23rd and then they said it would be only a couple of days to put up. It's really exciting to see things happening now. Jet Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15812 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6935 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6985 |
