Browse Forums Building A New House 1 Apr 09, 2015 1:21 pm Hi all, looking for some feedback from some inspired members to help / suggest the best thing to do. We've decided on the Oleria house from Sekisui house, but we're trying to find the best way to break it down / lay it out on our sloping block. We're trying to avoid to much cut, drop edge beams and retaining walls. Any input would be more than appreciated (I've spent months racking my brain) Here are 5 alternatives I've come up with so far, basically we are up the top of a hill, with the slope rising to the back left corner of the block. I'll give a brief description of each layout. 1. This is the simple layout with the first level having the main bedroom, entrance and garage Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2. This is the Oleria No2 layout, lends itself to better layout of stairs Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3. Just the garage and entrance are on the bottom level and the rest of the house on one level. The house is slightly sloped too to reduce cut and give better views from the outdoor area. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 4. Similar to 3 but not on a slope Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 5. Here the house is dissected a bit, the garage is now next to the main bedroom and the entrance has stairs leading to the house which is all on one floor. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building in Moncrieff, ACT Builder: Sekisui House Initial Deposit: Dec, 2014 - Infinity Upgrades and Air Con Re: Help with home layout on block 2Apr 09, 2015 2:20 pm I like 4! Have no wise words about the most cost effective but the inclusion of stairs will give the entry a little bit of drama, would also give an awesome raised deck opportunity off your living areas! What about stairs to the minor bedrooms in plan 4? You could keep the same roof line by increasing the ceiling height in the living areas to match the raised bedroom wing. Re: Help with home layout on block 3Apr 09, 2015 2:26 pm Thanks for the suggestion, yeah we're under the impression we'll get more back yard and better views from our house keeping the house aligned to the west fence. I've considered stairs to the back bedrooms, my wife was a little concerned though as we have a 2 and 4 year old but I tried explaining it would be alright. The other thing too is if someone needed to use the toilet they would have to climb stairs.... Either that or perhaps just stairs to the bathroom and back two bedrooms, not the toilet and bed 2. Building in Moncrieff, ACT Builder: Sekisui House Initial Deposit: Dec, 2014 - Infinity Upgrades and Air Con Re: Help with home layout on block 4Apr 09, 2015 2:37 pm Never design a house around a child, they grow up! I was thinking stairs into that whole bedroom wing (from the family room!) Re: Help with home layout on block 5Apr 10, 2015 10:13 pm Thanks for the suggestions, taken it in and revised it a little bit. Here's the latest Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers! Building in Moncrieff, ACT Builder: Sekisui House Initial Deposit: Dec, 2014 - Infinity Upgrades and Air Con Re: Help with home layout on block 6Apr 13, 2015 6:42 pm Here is the design we are submitting! Thanks for the kind comments, really helped us out. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building in Moncrieff, ACT Builder: Sekisui House Initial Deposit: Dec, 2014 - Infinity Upgrades and Air Con You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 15586 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6128 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8403 |
