Browse Forums Building A New House 1 Apr 06, 2015 8:22 pm Hi all, We just bought a plot of land in Point Cook and have been looking at display homes for the past few weeks. We liked a display home and plan from Porter Davis Our concern is that PD uses waffle pod slabs for the foundation. PD has mentioned that they use the best waffle pod slab designs in the industry. Since I am in one of the western suburbs which has had issues with waffle slab heaves in the recent past, I am feeling a apprehensive. I am sure many of you have been through this decision dilemma. So seeking your help with understanding how safe it is to go with this type of foundation in the western suburbs. Thanks Rispar Re: Liked a Porter Davis home, concerned about Waffle pod sl 2Apr 06, 2015 8:36 pm I previously built with a raft slab and also 9 years ago with a waffle pod slab at Werribee. It wouldn't worry me to have a waffle pod slab again. For more opinions see (http://www.anewhouse.com.au/2012/09/waf ... raft-slab/) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Liked a Porter Davis home, concerned about Waffle pod sl 3Apr 06, 2015 8:59 pm I was in a similar place that you are at with waffle pod issues but with Simonds Homes in the north of Melbourne. Check out slab heave thread on this site. They need to be protected from water. Have a read of the very very long thread. It may just ease your mind. I am comfortable with them now but I will be doing a lot of slab protection, a lot on my coin too I might add. viewtopic.php?f=1&t=64836 Re: Liked a Porter Davis home, concerned about Waffle pod sl 4Apr 07, 2015 10:19 pm Thanks bashworth and goody59 for the links. Bashworth, do you see any merit in PD's claims that they use 4-5 tons of steel in their waffle slabs compared to 2 tons by other builders? PD provides 7 years structural warranty compared to 50 years from Henley for a raft slab. Even Boutique homes provides 25 years on their waffle slabs. Goody59, what slab protections do you suggest? Don't builders take measures to protect the slabs? I read thru quite a few pages of the forum thread goody59 mentioned. Waffle pod slabs have been in use for the past 15 years or so, is that enough time to prove its worth? Based on the reading, even the Australian standards did not account for post-drought conditions when it was formed. Re: Liked a Porter Davis home, concerned about Waffle pod sl 5Apr 07, 2015 11:11 pm rispar Thanks bashworth and goody59 for the links. Bashworth, do you see any merit in PD's claims that they use 4-5 tons of steel in their waffle slabs compared to 2 tons by other builders? PD provides 7 years structural warranty compared to 50 years from Henley for a raft slab. Even Boutique homes provides 25 years on their waffle slabs. Goody59, what slab protections do you suggest? Don't builders take measures to protect the slabs? I read thru quite a few pages of the forum thread goody59 mentioned. Waffle pod slabs have been in use for the past 15 years or so, is that enough time to prove its worth? Based on the reading, even the Australian standards did not account for post-drought conditions when it was formed. The drains need to be engineered and construction completed by builders as designed by the engineers. Even during construction, builders have site drainage requirements and slab protection. They are not allowed to let water pool up against slab inundating the sub slab soils to get saturated. So good drain design and placement and good site management using such methods such as tempory downpipes into storm water drains once roof is in place. Where I step in is as the owner is to protect my slab after handover with good landscaping practices to make sure water doesn't get under my slab. I will be placing a concrete apron 1 metre wide around my house that has a required fall away from the house and that apron will contain spoon drains that will drain surface water from path/apron into storm water drains and not just run off the path's edges onto the soils saturating the soils. It is like putting a broad rimmed hat on the slab. So just good landscaping practices. CSIRO have information on this procedure. Ideas can be taken from google of the issue. This forum has threads regarding protection of the slab. Re: Liked a Porter Davis home, concerned about Waffle pod sl 6Apr 07, 2015 11:14 pm rispar Thanks bashworth and goody59 for the links. Bashworth, do you see any merit in PD's claims that they use 4-5 tons of steel in their waffle slabs compared to 2 tons by other builders? PD provides 7 years structural warranty compared to 50 years from Henley for a raft slab. Even Boutique homes provides 25 years on their waffle slabs. The extra steel will help reduce cracking of the slab. . . But if the extra steel means they reduce the depth of the concrete the slab may not be any stronger. Problems of soil heave will occur independantly of the strength or the amount of steel. With the recent legal issues that have been highlighted in the press most builder will now being more careful as their insurers won't want to be hit by claims. As far as guarantees are concerned ou may find this post of interest http://www.anewhouse.com.au/2014/07/new ... arranties/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Liked a Porter Davis home, concerned about Waffle pod sl 7Apr 08, 2015 8:50 am rispar Thanks bashworth and goody59 for the links. Bashworth, do you see any merit in PD's claims that they use 4-5 tons of steel in their waffle slabs compared to 2 tons by other builders? PD provides 7 years structural warranty compared to 50 years from Henley for a raft slab. Even Boutique homes provides 25 years on their waffle slabs. Goody59, what slab protections do you suggest? Don't builders take measures to protect the slabs? I read thru quite a few pages of the forum thread goody59 mentioned. Waffle pod slabs have been in use for the past 15 years or so, is that enough time to prove its worth? Based on the reading, even the Australian standards did not account for post-drought conditions when it was formed. Henley provides 50 year structural warranty on both raft and waffle pod slabs, I am building with Henley and they have used waffle pod slab on mine with 50 year structural warranty for the house. Cheers Building Monaco Q2 with Henley in Wollert The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 9818 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 3819 House movement is always a potential problem and there is a cause. Yes you should have it inspected by a competent and experienced building consultant 2 7029 |
