Doing you own Electrical work with Carlisle Home
Sux... cause you would save a packet but not sure how it would work with the builders guarantee.
I wasn't even allowed to use my own roof insulation for this reason.
So what you need to understand here is that you will still be charged the same rate for electrical in the contract , the builder will pay you as a contractor to do the work , but you have the piece of mind that you did the work and should be able to save on upgrade costs as you can just do those ( or should be able to ) .
The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give…
30/08/2023
Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill…
7/02/2024
Anyone using Bellriver bulder and doing the turnkey projects
