Browse Forums Building A New House 1 Apr 02, 2015 4:45 am We need a 5.8m splash back window in our kitchen. Problem is, it's obviously bigger than standard windows and our builders supplier told me they won't do a custom size. I want to avoid having two next to each other with the aluminium post between. I took the below photo in a metricon house when there are two sheets of glass joined but no aluminium frame in between. Anyone know who supplies windows for metricon or do you happen to know another company that would do a custom window? Thanks in advance! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Splash back windows 2Apr 03, 2015 12:26 pm I don't know anyone who would do the longer window, we are having a similar length splash back window in our kitchen, however it is two 9c wide windows (2.1m), separated by 20cm of brick. Our Custom Dale Alcock build in the Village at Wellard https://forum.homeone.com.au/viewtopic.php?f=31&t=78620 Re: Splash back windows 3Apr 03, 2015 12:29 pm Can only imagine the costs would be crazy for a window that wide in a load bearing wall. The beam above it to hold roof will be impressive. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Splash back windows 4Apr 03, 2015 4:12 pm I spoke to Stegbar and they will do it for $2,300. Woo. But yeah didn't think about the load bearing wall issue... Whoops. M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Splash back windows 5Apr 03, 2015 4:30 pm MrsJM I spoke to Stegbar and they will do it for $2,300. Woo. But yeah didn't think about the load bearing wall issue... Whoops. When we did ours with M, if the window is longer than a certain length, you need to pay to have additional structural steel to support the wall above the window. From memory, it was if the window is longer than 3m. BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Splash back windows 6Apr 03, 2015 6:54 pm Shambini MrsJM I spoke to Stegbar and they will do it for $2,300. Woo. But yeah didn't think about the load bearing wall issue... Whoops. When we did ours with M, if the window is longer than a certain length, you need to pay to have additional structural steel to support the wall above the window. From memory, it was if the window is longer than 3m. do you happen to remember the cost of the steel beam shambini? M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Splash back windows 8Apr 03, 2015 8:34 pm MrsJM Shambini MrsJM I spoke to Stegbar and they will do it for $2,300. Woo. But yeah didn't think about the load bearing wall issue... Whoops. When we did ours with M, if the window is longer than a certain length, you need to pay to have additional structural steel to support the wall above the window. From memory, it was if the window is longer than 3m. do you happen to remember the cost of the steel beam shambini? The salesperson said it would be at least one thousand BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Splash back windows 9Apr 07, 2015 7:00 am Ooo looks good!! M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Splash back windows 10Apr 07, 2015 7:00 am Shambini MrsJM Shambini [quote="MrsJM"]I spoke to Stegbar and they will do it for $2,300. Woo. But yeah didn't think about the load bearing wall issue... Whoops. When we did ours with M, if the window is longer than a certain length, you need to pay to have additional structural steel to support the wall above the window. From memory, it was if the window is longer than 3m. do you happen to remember the cost of the steel beam shambini? The salesperson said it would be at least one thousand[/quote] Thank you M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15292 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6897 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6973 |
