Browse Forums Building A New House 1 Mar 22, 2015 4:00 pm Does anybody know if to comply with BAL 12.5 in Victoria that windows that can be opened need to have metal type mesh screens fitted? What about doors, do they require screens too? Do builders need to supply and fit screens prior to handover and to comply with all regs? I know I am paying an extra $4500 for BAL 12.5 but don't have all the specifications that compliance means as far as construction goes. Re: BAL 12.5 and windows and doors. 2Mar 22, 2015 4:20 pm Im building in nsw so unsure if its the same. My BAL is also 12.5 and yeah we need aluminium mesh to all openings. We are paying $5000 for the BAL upgrades and the mesh is included in that price. My builder will have them fitted for handover. Re: BAL 12.5 and windows and doors. 4Mar 28, 2015 12:01 pm Have a read of the following document, tells you everything you need to know. https://www.awa.org.au/documents/item/174 Re: BAL 12.5 and windows and doors. 6Apr 01, 2015 5:34 pm Please see below requirements for the BAL 12.5: Provide bushfire rated construction to comply with clauses 5.4, 5.5, 5.6, and 5.8 of the Australian Standard AS 3959-2009 and shall incorporate, but is not limited to, the following items to achieve BAL 12.5 EXTERNAL WALLS * Vents and weepholes to be screened with aluminium mesh with maximum aperture size of 2mm. * Lightweight cladding may be fibre cement sheet cladding not less than 6mm thick OR bushfire resting timber OR any combination of these. * Finish all joints in the external surface material of walls to prevent gaps greater than 3 mm. SCREENS * Screens shall be aluminium framed with aluminium mesh with maximum aperture size of 2mm and shall fit to window openings to prevent gaps greater than 3mm. * The openable portions of windows shall be screened. Note: Screen doors to external sliding doors not included. WINDOWS * Frames and glazing, if less than 400mm from an external 'horizontal surface' shall have frames made from metal or fire resistant timber and shall have Grade A safety glass minimum 4mm thick. DOORS * Provide weather strips or draught excluders/seals at base of all external hinged doors. * MADINF4G BAL-12.5 compliant front entry hinged doors * BAL-12.5 compliant flush panel external hinged door with metal kick-plate (externally) to garage rear access. * Front entry and garage rear access doors (if applicable) to have frames made from metal or fire resistant timber. * Garage doors to be fitted with weather strips, draught excluders/seals (EMB-A-SEAL), with gaps not greater than 3mm. *Sliding doors frames shall be made from metal or fire resistant timber and shall have Grade A safety glass complying with AS 1288 OR be protected by an external screen complying with clause 5.5.1A. ROOFS * Tiled roofs to be fully sarked directly below roof battens and extending into gutters and valleys. Prevent gaps where sarking meets fascias, gutters, valleys and the like. * Sheet roofing may have foil-backed insulation installed over battens. * Gaps greater than 3mm to be screened with aluminium mesh with maximum aperture size of 2mm. * Butterfly closers at/near ceiling level to evaporative cooling system OR non-combustible cover with mesh made of SS, bronze or aluminium, maximum aperture size of 2mm * All tiled and sheet roofs and eave penetrations (including roof ventilators, roof mounted evaporative cooling units if applicable) shall incorporate metal screens and be sealed with non-combustible material to prevent gaps greater than 3mm. * Sealant to Roof penetrations to be non combustible * Provide roof ventilation (1 No. Whirlybird with inserted “spark-guard” mesh) to fully sarked roofs to comply with the B.C.A requirements. UTILITY SERVICES * All above ground exposed pipes (water & gas) to be metal. I just got this reply from Simonds Homes re BAL 12.5 when asked the question. Posted for information of new home builders in a BAL 12.5 in Victoria. 3 4177 Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10934 |
