Browse Forums Building A New House 1 Mar 12, 2015 10:16 pm Hi We are looking at a 4mm Oak engineered floor. To be glued onto particle board directly. On the upper level. It has been suggested to us that the acoustic mat works best on concrete. With our use on the upper level its ability to reduce/insulate against noise, either from the tic tic of the engineered floor itself or from downstairs up/us to downstairs is very minimal. If anyone has an engineered floor upstairs, not floating with or without an acoustic mat I'd be very interested in your experiences. As an alternative I think we could try acoustic bats. But the area is 244m2 Thanks Re: Flooring - Acoustic under mat - Necessary? 2Mar 13, 2015 6:07 am Not only is acoustic underlay for sound but you can get acoustic underlay that has anti-bacterial and moisture shielding properties too with some including a thermal insulator. We have bamboo 14mm on concrete and put in an underlay that does all these things. Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Flooring - Acoustic under mat - Necessary? 3Mar 13, 2015 9:05 am Hi Light I didn't know that. Moisture upstairs is something one certainly wishes to avoid. We don't have aircon and I hoped the warmer air circulating above, as long as humidity was low, would help there. Anti-bacterial properties too, interesting. I would have thought sound would be mitigated by a mat but we have been informed by the timber floor people we would be wasting our money with it upstairs, so others experiences here are important to listen to. Thanks for the heads up. Re: Flooring - Acoustic under mat - Necessary? 4Mar 13, 2015 9:52 am acaicas Hi Light I didn't know that. Moisture upstairs is something one certainly wishes to avoid. We don't have aircon and I hoped the warmer air circulating above, as long as humidity was low, would help there. Anti-bacterial properties too, interesting. I would have thought sound would be mitigated by a mat but we have been informed by the timber floor people we would be wasting our money with it upstairs, so others experiences here are important to listen to. Thanks for the heads up. Yeh, we did a bit of research too and one of the things we found out is that the acoustic stuff is actually more about sound going up, not down through the cement floor on the first floor. It's like a cushioning effect that reduces the amount of sound bouncing up.. well.. I'm no expert so I don't know how to properly explain it.. but yeh.. they are kind of right about it not really having much effect in regards to stopping noise travelling down.. but all the other properties of an underlay are important for protecting the wood from the bottom. I don't think underlay is all that expensive from memory but it does of course increase the costs regardless.. Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4815 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7935 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16142 |
