Browse Forums Building A New House 1 Mar 12, 2015 9:07 pm hi has anyone built the hardford or like the floorplan with hickin, I'm wanting to add down lights instead of normal light, double power points and two in each room, turn the connected u shape breakfast bar into a break fast bar with a gap ( if that make sense) and a bifold in to alfresco area but wondering how much it would be? has anyone added extras on their house? Re: building with hickingbotham hartford 2Mar 13, 2015 2:36 pm Hi there, I think I already replied to another of your posts? I can help you out on the downlights & double power points. Are you actually reducing the size of the breakfast bar? - I would think there would be no extra cost. I believe bifolds are expensive, what size? We are having 2 sliding doors beside each other to give a bigger wall of glass, I can get the price for that for you at home. From memory the downlights are a lot, you may need to reconsider unless you have a large budget! Re: building with hickingbotham hartford 4Mar 17, 2015 9:04 am The LED downlights are $180 each, I have heard that you can get it done after build for around $80 - $100 each. Maybe visit a lighting shop and see if there is anything you like as an alternative? You would have to ask your salesperson about breaking the breakfast bar, if you are leaving the sink as on the plan I think you should be ok. If you want to move it to the breakfast bar there may be some additional plumbing involved. Are you sure you will have enough bench space if you chop a section of it off? go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 111313 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11391 |
