Browse Forums Building A New House Re: Inspections @ every stage of build process 3Mar 12, 2015 8:29 pm rmjose18 we used houspect..really good! Hi rmjose, rang the houspact guys. They seems to be bit pricey. But then the lady was very confident of the services they provide, etc. Also, learned that "inspection service" is not regulated in NSW meaning anyone can wear the hat hat of "building inspector" with/without any formal accreditation. Bit frightening if this is the case. Will check few others, before deciding.. Any other names ???? Re: Inspections @ every stage of build process 4Mar 12, 2015 9:03 pm ProgD rmjose18 we used houspect..really good! Hi rmjose, rang the houspact guys. They seems to be bit pricey. But then the lady was very confident of the services they provide, etc. Also, learned that "inspection service" is not regulated in NSW meaning anyone can wear the hat hat of "building inspector" with/without any formal accreditation. Bit frightening if this is the case. Will check few others, before deciding.. Any other names ???? We're going with Houspect too. They do a discount for packaged inspections, that is if you essentially "preorder" all your inspections at the beginning in a package. From memory, 5 stages of inspection is going to set us back just over $2000 but that includes the waterproofing stage as well, which is something they said was occasionally difficult to time because if the builder's certifier/inspector is there at the time the waterproofing is done and it gets certified, then the tilers start work straight away, they might not be able to do a complete check of waterproofing at which time we can opt for a partial inspection of what is available to be inspected or just get a refund. I appreciated their honesty in this aspect of the inspections. Compared against other good inspectors, this is quite a competitive price. The other prices I have seen around the forums are averaging about $490 per inspection.. Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ 4 6825 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18064 I apologise for any confusion, but your understanding is correct. We approached our situation differently based on advice from… 11 53211 |
