Browse Forums Building A New House 1 Mar 11, 2015 3:50 pm Finally we are about to start external and internal selection very soon. We are building with Firstyle. For the external selection I am thinking to use: Roof: Magnum Roof Gutter: Woodland Grey (apparently if monument will be better, but the monument colour is not on the list Fascia: Dune Eaves: Dune or Surfmist Bricks: Austral Everyday Life Freedom Downpipe: Woodland Grey Render: Dune/ June Fog (Light Grey) Window: Woodland Grey. Door: Stained (thinking wood colour) Mortar: Off White I am sooooooo confused.. and worried if these colours are not matching.... We are building 4 bedroom with 1 garage and we also have corner facade... Anyone can shed lights or anyone used similar colours ? Appreciated Cheers Thornton23 Aug-Oct 2014 Deposit Tender April 2015 Land titled Jun-Jul 2015 Final Tender &Clipsal Aug 2015 DA approved Jan 2016 Slab Feb 2016 Frame Apr 2016 Brick June 2016 Roof July 2016 Lock up Re: External Colours Selection Help 3Mar 11, 2015 8:05 pm Everyday Life is a series of Austral bricks, so it may help to be more specific about which one. The mortar colour will have an impact too. Re: External Colours Selection Help 4Mar 12, 2015 12:50 pm oneJohn Everyday Life is a series of Austral bricks, so it may help to be more specific about which one. The mortar colour will have an impact too. Aw I accidently type Austral doubled. We are thinking to get Austral Everyday Life Freedom. Thornton23 Aug-Oct 2014 Deposit Tender April 2015 Land titled Jun-Jul 2015 Final Tender &Clipsal Aug 2015 DA approved Jan 2016 Slab Feb 2016 Frame Apr 2016 Brick June 2016 Roof July 2016 Lock up Re: External Colours Selection Help 5Mar 12, 2015 1:09 pm Pink86 Check out colourtouch.com.au it will give you an idea of what your trying to picture Thank you I will give it a try hope they have brick colours i have Thornton23 Aug-Oct 2014 Deposit Tender April 2015 Land titled Jun-Jul 2015 Final Tender &Clipsal Aug 2015 DA approved Jan 2016 Slab Feb 2016 Frame Apr 2016 Brick June 2016 Roof July 2016 Lock up Re: External Colours Selection Help 6Mar 12, 2015 1:56 pm I am using colourtouch.com.au but somehow it doesnt give me flexibility to add the render to the other wall. Only 1 wall can be rendered.. So I try to use envisage simulator. It is not giving me visibility/full picture as the type of the house is a bit different especially the facade. I wonder why they dont have Austral bricks in the simulator.. the brick colours are different from what i have in this picture... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Anyone have suggestion or idea where I can apply Freedom or suggestion I think the freedom bricks are brownish and reddish colour Thornton23 Aug-Oct 2014 Deposit Tender April 2015 Land titled Jun-Jul 2015 Final Tender &Clipsal Aug 2015 DA approved Jan 2016 Slab Feb 2016 Frame Apr 2016 Brick June 2016 Roof July 2016 Lock up Re: External Colours Selection Help 7Mar 12, 2015 2:45 pm You will not find a visualiser with you exact home facade, they are all pretty much standard. There are heaps online e.g. colour bond have one & also Austral Bricks have one too that may give you an idea on your brick choice. Re: External Colours Selection Help 8Mar 12, 2015 3:23 pm We've chosen very similar colours: Roof: Monier Tiles in Barramundi Gutters: Monument Fascia/downpipes: Dune Bricks: Biscotti (main), Praline (feature) Mortar: Off White Render: Dune Cladding: Surfmist Window frames: Black Garage door/front door: Dune Driveway: Gunmetal Grey Not sure if I've done this right but here is a photo of our samples FYI: https://www.imageshack.us/i/eyTNlRD2j Good luck!! I found it really stressful and needed two appointments to get it right. Re: External Colours Selection Help 10Mar 12, 2015 3:53 pm Pink86 You will not find a visualiser with you exact home facade, they are all pretty much standard. There are heaps online e.g. colour bond have one & also Austral Bricks have one too that may give you an idea on your brick choice. You are right Pink86, I was trying to use the imagination. Hopefully this colour combination will work okay as our garage is only one and will not give 'small' looks to the house . I will try Austral one very soon. Thornton23 Aug-Oct 2014 Deposit Tender April 2015 Land titled Jun-Jul 2015 Final Tender &Clipsal Aug 2015 DA approved Jan 2016 Slab Feb 2016 Frame Apr 2016 Brick June 2016 Roof July 2016 Lock up Re: External Colours Selection Help 12Mar 13, 2015 3:23 pm d@n What does your facade look like? Here is my Front Facade will look like (BTW, it will be rendered for the facades) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here is my side Facade: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So Not sure with my colour will give very dark look as it is only 1 garage house. Thornton23 Aug-Oct 2014 Deposit Tender April 2015 Land titled Jun-Jul 2015 Final Tender &Clipsal Aug 2015 DA approved Jan 2016 Slab Feb 2016 Frame Apr 2016 Brick June 2016 Roof July 2016 Lock up Re: External Colours Selection Help 13Mar 13, 2015 8:10 pm Re: External Colours Selection Help 14Mar 13, 2015 8:19 pm priscia2104 Here is my Front Facade will look like (BTW, it will be rendered for the facades) Do you mean the entire front will be rendered? What's your garage door colour? I think you're colours are fine. Just maybe lighten it up a bit. eg have lighter windows. Re: External Colours Selection Help 15Mar 14, 2015 11:51 pm d@n priscia2104 Here is my Front Facade will look like (BTW, it will be rendered for the facades) Do you mean the entire front will be rendered? What's your garage door colour? I think you're colours are fine. Just maybe lighten it up a bit. eg have lighter windows. Hi d@n, thank you for backing me up and yes the front facade will be fully rendered. I am thinking either Dune or June Fog (Light Grey colour). For the garage, it will be Woodland Grey. Uhm Do you think Iron Stone will be lighter enough to replace Woodland Grey for the Window? Thornton23 Aug-Oct 2014 Deposit Tender April 2015 Land titled Jun-Jul 2015 Final Tender &Clipsal Aug 2015 DA approved Jan 2016 Slab Feb 2016 Frame Apr 2016 Brick June 2016 Roof July 2016 Lock up Re: External Colours Selection Help 16Mar 14, 2015 11:52 pm Wow, thank you for this one. It is a bit similar. I will try to play around Thornton23 Aug-Oct 2014 Deposit Tender April 2015 Land titled Jun-Jul 2015 Final Tender &Clipsal Aug 2015 DA approved Jan 2016 Slab Feb 2016 Frame Apr 2016 Brick June 2016 Roof July 2016 Lock up Re: External Colours Selection Help 17Mar 15, 2015 7:37 am priscia2104 Hi d@n, thank you for backing me up and yes the front facade will be fully rendered. I am thinking either Dune or June Fog (Light Grey colour). For the garage, it will be Woodland Grey. Uhm Do you think Iron Stone will be lighter enough to replace Woodland Grey for the Window? No ironstone and woodland grey are similar tone strength. Since your render colour is light then dark windows should be fine. But I think you need some variety with either an additional render colour or brick choice. The portico is an ideal choice to create a feature. Re: External Colours Selection Help 18Mar 15, 2015 5:06 pm For the comments so far to make sense, I'm thinking OP may be using the term "facade" to refer to just the portico, rather than the full facade (front) of the house. Re: External Colours Selection Help 19Mar 15, 2015 9:01 pm d@n priscia2104 Hi d@n, thank you for backing me up and yes the front facade will be fully rendered. I am thinking either Dune or June Fog (Light Grey colour). For the garage, it will be Woodland Grey. Uhm Do you think Iron Stone will be lighter enough to replace Woodland Grey for the Window? No ironstone and woodland grey are similar tone strength. Since your render colour is light then dark windows should be fine. But I think you need some variety with either an additional render colour or brick choice. The portico is an ideal choice to create a feature. Thanks d@n. We went to display house today and thinking to get surfmist colour for fascia and render intead of dune for even lighter grey colour. Do you have suggetion what other mixing render colour we need to get especially portico and the facade section.. ps I also have corner facade... Re: External Colours Selection Help 20Mar 15, 2015 9:05 pm oneJohn For the comments so far to make sense, I'm thinking OP may be using the term "facade" to refer to just the portico, rather than the full facade (front) of the house. Good suggestion. We can do that.. The Dulux colour consultants are awesome. If you show them the photos they should be able to figure it out for you straight away 1 1612 Hi there, we have classic cream gutters, fascia’s, roller door and undercover carport. We are are going to paint the roof a terracotta orange colour. After some… 0 4499 Thanks Pulse, thats really helpful and very much appreciated. Also thanks for the pointer on sheathing, thats me watching too many american youtube videos! 6 2788 |
