Browse Forums Building A New House 1 Mar 10, 2015 2:00 pm There have been a few threads on slabs recently and as we are not far away from getting ours poured I am considering getting an inspection completed to make sure everything is A-Ok. My question is which is best - Pre-pour or post? I can see benefits of both. One company we have looked at does it pre-pour but then doesn't check the slab until the roof frame is up. That seems a bit late if there are cracks etc. The other company does a post-pour inspection. So they don't check the pipes etc except for positioning once the slab is down, but it's before any bricks go on etc so any cracks should be dealt with more easily. What are people's opinions on which is best? Re: Pre-Slab Inspection or Post Slab Inspection?? 2Mar 10, 2015 2:32 pm nikkis2000 There have been a few threads on slabs recently and as we are not far away from getting ours poured I am considering getting an inspection completed to make sure everything is A-Ok. My question is which is best - Pre-pour or post? I can see benefits of both. One company we have looked at does it pre-pour but then doesn't check the slab until the roof frame is up. That seems a bit late if there are cracks etc. The other company does a post-pour inspection. So they don't check the pipes etc except for positioning once the slab is down, but it's before any bricks go on etc so any cracks should be dealt with more easily. What are people's opinions on which is best? Preslab pour has to be the important one from that choice. Once slab poured, it is not a good time to find it was done with avoidable issues. Re: Pre-Slab Inspection or Post Slab Inspection?? 3Mar 10, 2015 3:00 pm pre-slab inspection! the amount of pre-slabs ive seen without enough damp course laid, mesh not over lapping enough or missing, corner bracing missing its all shocking! Re: Pre-Slab Inspection or Post Slab Inspection?? 4Mar 10, 2015 8:00 pm I voted pre-slab but I think a frame/slab inspections is important Re: Pre-Slab Inspection or Post Slab Inspection?? 5Mar 11, 2015 10:47 am Thanks for the replies. Looks like pre is the way to go which I was kind of edging towards too. Just need to let RedInk know as they were only going to get in touch once the slab was down - this could be interesting! Re: Pre-Slab Inspection or Post Slab Inspection?? 6Mar 11, 2015 12:38 pm I do a lot of pre slab inspections and can see limited value in it after the slab is poured Firstly you cannot check formwork lines, builders plastic,position of pipe risers (or if they are loose) reinforcing and termite protection. It's also too late for general set out, site excavation, levels and drainage. At frame inspection any problems will be apparent and usually can be fixed. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog The worst thing you can do is sign a building contract without a pre contract review. Over the years many people have come to me with disputes where they just signed… 0 8348 There are a lot of private inspectors should have stayed working as tradies!! Firstly, you paid for a professional opinion of the works, if he has picked up on an item he… 1 2051 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18821 |
