Celebration Homes - Cornice (ceiling)
OneJohn - exactly! if there is no wall to ceiling connection why put in the cornice? As I mentioned above it is located somewhat to delineate area of the house with the same ceiling height. In one instance I saw a cornice between living and entry. In some instances it's located where a door header ought to be located.
Do you have a photo of this? Is it built yet or are you making assumptions from the plans?
http://www.celebrationhomes.com.au/disp ... /blanchett - - - slides 4 6 7 8
It's like a 90mm deep bulkhead over an opening. It's probably there just for asthetic reasons, and you should be able to remove it. However, it is possible they are running a beam across that space to brace the outside wall off the internal wall. If so, the alternatives would be to run it down lower, and make it look more like a bulkhead, or to instead run a beam across in the ceiling space - which may be more costly.
8
The photo is not really clear but to me it looks like twist in the cornice. Slight anticlockwise rotation at the top of the cornice and slightly clockwise at bottom should…
17/06/2023
How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity?
28/06/2023
There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water…
