Browse Forums Building A New House 1 Mar 05, 2015 8:22 pm Hi All,
Just settled on a bargin block in Carine. Have decided to build with Ben Trager as their designs suited our needs with two master suites. Settled on the Cardini with the following changes. Widened the garage by a metre and also added 900mm to the length to fit my truck. Deleted the study and changed it into a scullery. Removed the island bench as i ran into trouble with my current house's island bench with a cracked hotwater pipe which cause huge problems to get fixed. Redesigned the laundry. Extended the robe in bedroom 3 to the whole length of the room. Put a wall up next to the staircase on the second floor and slide the bathroom down to the front of the house and made a huge wardrobe where the bathroom was. Doubled the size of the alfreco to accommodate a dining area and lounge areas and a wall at the end to place a tv outside. Added storage to the underside of the stairs. please give comment to my posts on my design and ideas during my build. Timeline 06/01/15 Made contact with Ben Trager 24/01/15 Purchased block in Carine 29/01/15 Modify plans 16/02/15 Sketches drawn up to our specifications 13/05/15 Demolition 20/08/15 Prestart 27/08/15 Costings Prestart 09/09/15 Pool contract signed 09/10/15 City of Stirling requesting planning permit 27/10/15 Final Plans drafted 10/11/15 Smart Wiring finalized 24/11/15 Planning approval and building permit 05/01/16 Pool installed 05/02/16 Sand Pad down 17/02/16 SLABBED!!! 01/03/16 Sand, Bricks and Window Frames 05/03/16 Brickies ONSITE 10/04/16 Lower Brickwork complete 17/04/16 Roof Trusses for second floor complete 16/05/16 Upper framing complete 27/06/16 Upper floor eaves, gutters and render painted 14/07/16 Roof Carpentry completed 07/08/16 Colorbonded 13/08/16 Aircon ducts installed 22/08/16 Grey float and insulation completed 05/09/16 Upper floor walls, celings, cornices completed 12/09/16 Plastering complete 16/09/16 LOCKUP!! without windows? Stairs installed 21/09/16 Shelving completed for linen and wardrobes 30/09/16 Ceilings painted and first coat on walls 04/10/16 Windows installed 27/10/16 Cabinets installed 03/11/16 Becnhtops installed 11/11/16 Tapware and tiling completed 13/11/16 Painted started and data points installed 03/02/17 Pre PCI building inspection. (Andrew Scales) 14/02/17 PCI Re: Ben Trager Build Carine 2Mar 05, 2015 8:28 pm Welcome to the BTH club ![]() Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Ben Trager Build Carine 4Mar 06, 2015 10:11 am Carport side of the house is the north side. The house faces east. Hopefully the house stays cool during summer with house facing east. Because of the dimensions of the block the carport needs to be on that side so the long alfresco area fits. Re: Ben Trager Build Carine 5Mar 06, 2015 10:51 am My comments would have been to initially design the orientation of the house if possible to meet solar passive principles such that your house is cool in summer but importantly warm in winter. That principle has living areas receiving northerly sun. http://www.yourhome.gov.au/passive-design Other comments are - There seems to be a bit of a void/gap in ensuite next to the vanity – perhaps making this a long double vanity would be better use of space? - Main bathroom appears kind of small for size of family home but can’t see dimensions. Is there a way of pushing into bed 2 a bit more, then pushing bed 2 into theatre a bit more? good luck with the build. Re: Ben Trager Build Carine 6Mar 06, 2015 11:04 am my last house was east facing, front of the house was fine, it was more the west facing rooms at the back get toasted in the afternoon, so I'd minimise the glazing or at least upgrade it's thermal capacity. Re: Ben Trager Build Carine 7Mar 08, 2015 10:04 am Wow, looks fantastic, too many changes that I really like to mention, following........ Re: Ben Trager Build Carine 9May 13, 2015 6:32 pm Re: Ben Trager Build Carine 10May 13, 2015 6:36 pm Woohoo! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Ben Trager Build Carine 17May 24, 2015 1:14 am Admin was just under 6 months for us to slab and we're expecting 11-12 months for build time. I think you expect that kind of time frame when building 2 storey? Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Ben Trager Build Carine 18May 24, 2015 10:59 am 6 months for admin was the same for us, mainly cos we had to wait for land title. 11-12 months fm slab is also what we r working with. Seems ok to me with a 2 storey. At least I thought that was par for the course! Our build thread [url]https://forum.homeone.com.au/viewtopic.php?t=71492/url] Prestart: 18/7/14 Final plans: 13/8/14 Building permit: 30/9/14 Did the builder organise the certifier? You will probably find the builder hadn't paid the suppliers and it took him that long to finally pay them so you could obtain the… 1 15324 Hi all, We are currently just up to lockup stage. Well our portal says lockup complete but our electrical is being done this week, so in theory, fully completed lockup by… 0 13750 The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 28879 |
