Browse Forums Building A New House Re: opinions on which plan 4Feb 28, 2015 3:39 pm Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: opinions on which plan 8Jun 25, 2015 1:09 pm The first plan definitely. In the second plan your Master Bed is about the size of a single bedroom. If you have kids, the amount of toys etc. is only going to grow (exponentially!) and you will appreciate having gone for the option with more space. Anthony Firstly, wow you have put a lot of work into your list of questions! Great job and they are mostly valid questions that a builder should be able to answer. As… 14 10692 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6346 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7558 |
