Browse Forums Building A New House Re: Which Floor Plan Do you think is better? 41Mar 31, 2015 8:59 pm Lovely plan - have not read through your whole thread but my vote was for plan 2 because of the more open living - especially the kitchen. Just a point that bugged me a lot in our house we built a few years ago - the main bathroom toilet - its too visible - line of sight from your living areas is to the toilet - can you put is sideways like in your ensuite even if you have to push bathroom out like the rear bedroom into the eave? Re: Which Floor Plan Do you think is better? 42Mar 31, 2015 11:01 pm bluesteel Lovely plan - have not read through your whole thread but my vote was for plan 2 because of the more open living - especially the kitchen. Just a point that bugged me a lot in our house we built a few years ago - the main bathroom toilet - its too visible - line of sight from your living areas is to the toilet - can you put is sideways like in your ensuite even if you have to push bathroom out like the rear bedroom into the eave? Would something like this work better or is it too awkward? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Re: Which Floor Plan Do you think is better? 44Apr 01, 2015 6:14 pm I think that works better. As long as it fits your furniture plan Follow my build here: viewtopic.php?f=31&t=74975 Re: Which Floor Plan Do you think is better? 45Apr 01, 2015 6:43 pm That's much better! Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Which Floor Plan Do you think is better? 46Apr 01, 2015 6:43 pm Wall between entry living still needs work lol Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Which Floor Plan Do you think is better? 47Apr 01, 2015 8:42 pm Lol I can live with that, maybe i could extend it more to the right as the entrance is now way bigger? Re: Which Floor Plan Do you think is better? 48Apr 02, 2015 10:40 am I was wondering if raising the alfresco to 31c would be better flow wise as the living area are all 31c? Also how much can I reasonable be asked to pay to upgrade from 28c to 31c for an alfresco of 8mx5m? Re: Which Floor Plan Do you think is better? 49Apr 02, 2015 10:43 am Going by the roof lines on your plan, the roof over the Alfresco will be at the same height as the house anyway. If it was to have a lower ceiling then it would have been framed down. My thought is that it should be a credit!! to increase height to match house. But it wont be.. never is lol Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Which Floor Plan Do you think is better? 50Apr 02, 2015 10:46 am I should word that a bit better.. The pitching point over the Alfresco is the same pitching point as the main house. The builder would normally run the ceiling through the Alfresco at the same height as the overhang, which would not be much on your plan as there is minimal overhang to that side Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Which Floor Plan Do you think is better? 51Apr 02, 2015 10:48 am So does it mean right now that at 28c on the plan, the Alfresco is basically framed down around 3c? Re: Which Floor Plan Do you think is better? 52Apr 02, 2015 11:29 am This is a very very VERY quick sketch lol. The bottom chord of the roof truss will be the same height right through so the ceiling to the Alfresco would be set down to match the end of the overhang. If you raise it, the section from the Alfreco beam will be boxed down. Still looks fine IMHO. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Which Floor Plan Do you think is better? 53Apr 02, 2015 11:31 am Thanks for the quick sketch lol. Is 28c enough for ceilings fan? Will 31c maybe allow more morning lights to the living areas? Re: Which Floor Plan Do you think is better? 54Apr 02, 2015 11:33 am The higher the better for ceiling fans lol. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Which Floor Plan Do you think is better? 55Apr 02, 2015 11:46 am So in theory, I shouldn't be charged to raise the ceiling to 31c? Re: Which Floor Plan Do you think is better? 56Apr 04, 2015 1:26 pm I think the ceiling heights are more complicated than it first appears. The eaves around the alfresco are 25c, which is consistent with the 28c ceiling of the alfresco. I think you'll find that more of the house is also 28c, like the scullery and garage, and maybe even the bedrooms. So the outer areas are built to 28c, and the inner ceilings are popped up higher. This reduces the outside wall heights, but I would have thought make the roof structure fairly complex. You could ask about bringing the ceiling of the whole house up to 31c, but I wouldn't count on getting that at the same price. Re: Which Floor Plan Do you think is better? 57Apr 04, 2015 2:49 pm No, The Scullery will be at 31c same as the rest of the house. Roof trusses are a pretty simple thing to understand (I use to detail them for truss plants for 5 years). The pitching line is the outside edge of the timber frame and if you look at the plan it clearly shows the Valley over the games coming up from the outside edge of the Alfresco. So the roof will be supported right over the Alfresco at the same height as the outside walls of the house. There would be a bulkhead (from the bottom of the facia to the inside edge of the Alfresco beam), but the rest of the Alfresco ceiling should have no reason it can not be set at 31c same as house. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Which Floor Plan Do you think is better? 58Apr 04, 2015 2:51 pm Oh.. and there will be a height difference of the fascia / gutter over the Scullery / Alfresco.. It will be higher than the fascia / gutter outside Bed 4 / Alfresco. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Which Floor Plan Do you think is better? 59Apr 04, 2015 2:55 pm Will it look odd or ugly to have different heights? What can de done to fix that? Re: Which Floor Plan Do you think is better? 60Apr 04, 2015 5:21 pm you just need to make the overhang the same length over the Scullery as it is over the other section. Same on the back of the bedrooms. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7561 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6626 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7257 |
