Binca
Has anyone that's moved in been able to connect to data points everywhere in the house?
Does it require connection from modem to data patch panel for it to start working? We've only managed to use wifi
Hi Binca,
You need to connect data cables from your modem to the required point on your data panel for internet to work....generally modem has only 4 or 5 ports with one going into NBN modem....if u want to connect all the you would need a switch as well....Hope it helps
