Browse Forums Building A New House 1 Feb 14, 2015 3:39 pm Hi All, Most builders are using the Timber grade F5 for Frame stage. with the following dimensions: Timber 90 x 35mm Ground Floor – 450mm centres First Floor / Single – 600mm centres Internal and external are the same. Did anyone Upgrade the Timber Frames to 90 x 45 MGP 10 with Henley . If so how much was the upgrade cost? Any advise would be greatly appreciated. Thanks aube This is 100% true. You can not hang anything on steel frames. very frustrating 8 7989 Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10483 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28312 |
