Browse Forums Building A New House Re: Building the Emporio ER432 with MainVue / Henley 21Feb 17, 2015 4:14 pm Hi Michael, thanks. From what I can see of my plans the front window above the stairs will be openable. I In the contract it says provide Wimbledon Façade timberwindows above Garage to Longbeach Façade (09-24). I did get a PCV reducing it slightly so it is now 850mmx2410mm due to insufficient space between window and garage roof, so it is still taller than it was and I am assuming still openable. If you look up in my thread there is a façade plan, on that you an see the window at each end will be openable (though we might only be able to open the one right near the middle landing with the help of a step ladder?. I have always been fussy about my stairs, and love landings - I don't have a price just for the platform, It is included as part of the price to upgrade the staircase to have stainless steel rod ballusters and timber handrail (instead of plaster wall with timber capping). With the electrical pre-wiring I had to give the locations of where I wanted everything. They were reluctant to pre-wire the alarm as it is different cabling. For the intercom I am having a screen downstairs near the dining room, and there will also be a screen upstairs. The CCTV is cat6 cables. I am so nervous about the wiring as there is literally going to be wires going everywhere so hopefully I have put everything where it should be. What façade have you chosen? I don't mind all the questions Michael - happy to help. sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Emporio ER432 with MainVue / Henley 22Feb 17, 2015 9:16 pm Thanks Sassid, Which facade have we chosen? ....that's the $1m question. Intention was always to select a facade without a balcony to maximise the backyard. Initially selected the Eclipse facade as we like the idea of all brick, however, having second thoughts. Now looking at the Ultima facade which uses some light weight materials instead of brick. Given we are upgrading the bricks, preference is to look at the bricks as opposed to render. Re the stairs, does the upgrade include steel rods, platform on ground level and timber instead of MDF for the 2nd flight of stairs? For the intercom, do you need power points for the 2 x video screens? If so, how would they conceal the power points? Where is the best place for all the wires to meet? Sounds like then often end up in the garage or under the stairs. cheers Michael ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Building the Emporio ER432 with MainVue / Henley 23Feb 17, 2015 11:09 pm The price is for the rods & bottom platform, I have opted to keep upper flight of stairs as carpet sort of for safety reasons and also to keep costs down. I love that our stairs have a big platform in the middle - not a fan of angled steps round corners. I'm not sure re: power points, they will probs be put in behind where intercom should be, then we can get them hard wired in when installed. Will definitely be going through all the wiring with supervisor & installer beforehand to double check it is all going to be done right. Hit water controllers location is still to be determined though, I was told that is done right before install. sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Emporio ER432 with MainVue / Henley 24Feb 17, 2015 11:12 pm Facades were so hard due to them being so expensive. We like the facades with balconies so opted for the cheapest facade available that included a balcony. MainVue do have nice facades either way though, just hard with not being able to render due to cost. sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Emporio ER432 with MainVue / Henley 25Feb 18, 2015 8:32 am sassid The price is for the rods & bottom platform, I have opted to keep upper flight of stairs as carpet sort of for safety reasons and also to keep costs down. I love that our stairs have a big platform in the middle - not a fan of angled steps round corners. I'm not sure re: power points, they will probs be put in behind where intercom should be, then we can get them hard wired in when installed. Will definitely be going through all the wiring with supervisor & installer beforehand to double check it is all going to be done right. Hit water controllers location is still to be determined though, I was told that is done right before install. Agree about the stairs, the large landing is a big +. We were also looking at the Palace design and while the orientation was the reason we opted for the Emporio, only issue I had with the Palace was the tighter staircase minus the landing. ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Building the Emporio ER432 with MainVue / Henley 26Feb 18, 2015 2:04 pm Our site supervisor works fast, after having site scrape Monday, fences on Tuesday, today we have had house peg out, re-establishment survey, and now I think power is getting to the site as there is another digger, so the meter box should be getting installed now... Here is our exterior colour style, as usual further information is on my blog. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Emporio ER432 with MainVue / Henley 27Feb 18, 2015 2:42 pm It's all happening..exciting times. Notice you found a colorbond sample for the Woodland Grey windows. For some reason, they dont have Woodland Grey samples on display at Cosham. ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Building the Emporio ER432 with MainVue / Henley 28Feb 18, 2015 7:11 pm Who knows when I picked up that sample, probably from house no. 2 as it is an A&L window sample. I am forever requesting samples - most of the companies will mail you out samples & have request forms on their website, even the paint companies can send out samples - I actually bought (small charge though) a4 paint swatches from dulux for the Waldorf. I got a free plank of the flooring from the supplier, ceasarstone and laminex samples, only thing I had trouble with last time was the carpet for the Waldorf - managed to find a stockist (PD use different names), ordered sample through a retailer but it never came. Should be easy to get Henley samples though as the names/codes match that at Carpet Call, will get onto that soon one day I think. The only thing I wish I had was a sample of the tiles, I only have my samples of similar tiles from PD. Though Colorbond mail out paper swatches not the actual metal ones.. sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Emporio ER432 with MainVue / Henley 29Feb 19, 2015 7:39 am Hahahahahahha sassid, I have a side table drawer with full of samples too. Your colours are going to look fabulous, great choice there Re: Building the Emporio ER432 with MainVue / Henley 30Feb 20, 2015 9:35 am Our Stair Style & Lighting Pics, more info on the blog... This is the Emporio staircase as displayed - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This it the styling I like, except with a clear (lighter) stain on the timerwork. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ These are the some of the lighting choices I found when looking for a light above the middle landing. To see which one I picked, and why, check out the blog post. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Building the Emporio ER432 with MainVue / Henley 31Feb 21, 2015 12:54 pm Our kitchen colours and styling - further details can be found on the blog... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Emporio ER432 with MainVue / Henley 32Feb 21, 2015 9:21 pm We have very similar colour choices! Which is reassuring for me! Hahaha I'll keep you posted how it pulls off... Re: Building the Emporio ER432 with MainVue / Henley 33Feb 21, 2015 9:34 pm tj9630 We have very similar colour choices! Which is reassuring for me! Hahaha I'll keep you posted how it pulls off... Great minds! What house are you building & what stage are you up to - would love to see some pics? Re: Building the Emporio ER432 with MainVue / Henley 34Feb 21, 2015 11:07 pm Hi Sassid, I think you had your electrical appoint only a couple of months ago. Did you recall if you had any issues requesting the pre-wires? When I raised it last week, was advised it's not something they normally do and they would need to raise a request. Cheers Michael ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Building the Emporio ER432 with MainVue / Henley 35Feb 21, 2015 11:14 pm Hi Michael, we did have some problems - we had the full install included but took them out to cut costs for valuation. Henley didn't have the intercom we were after. They were fine with the data points pre-wire (including CCTV since that just needs data cables) but had to push for the alarm/intercom pre-wires before they agreed, originally was told they would not do pre-wires for those - well at least for the alarm. I would have preferred them doing the install of the alarm equipment too but we had to make sure there would be no problems with the bank valuation. sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Emporio ER432 with MainVue / Henley 36Feb 21, 2015 11:24 pm Thanks Sassid, Given that you and Mirz had arranged pre-wiring, I thought it was a no brainer, hence my surprise when I was advised it's not something they normally do. Had my heart set on a Bosch alarm as I have friends who are very happy with their units. Notice you had a steam oven, had no idea they existed so I googled to find out more about them. Sounds like an excellent way to cook healthy meals. The electrical appointment went well, I didn't include the little lights on the side of the stairs due to cost, however, we came in a little under budget so we may be able to include. Cheers Michael ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Building the Emporio ER432 with MainVue / Henley 37Feb 22, 2015 12:17 am Glad the electrical appointment went well for you. When we renovated our last kitchen we got the steam oven, the only thing we are not replicating from our previous kitchen is the coffee machine. Steam ovens are great - you can also get combi ovens which mix steam with regular oven, but I like the straight steam oven. Have definately missed it while we are renting... We haven't put in the little stair lights either. For some reason they don't really appeal to me? Re: Building the Emporio ER432 with MainVue / Henley 38Feb 22, 2015 11:44 am sassid tj9630 We have very similar colour choices! Which is reassuring for me! Hahaha I'll keep you posted how it pulls off... Great minds! What house are you building & what stage are you up to - would love to see some pics? We have just started site works so still early stages, slab was suppose to be poured but the cyclcone has caused delays... So hopefully everything is back on track this week!! We have also organised our own electrical installs for data and cctv.... Organising your own electrical is technically not allowed by head office... but its often allowed when its organised by you with your site supervisor... I think you sign a document about it during your tender presentation... this blog used sublime teak in their build https://metriconadventure.wordpress.com/... looks amazing! Ive added your blog to my blog list too! Re: Building the Emporio ER432 with MainVue / Henley 39Feb 22, 2015 1:24 pm thanks for the links, could not see your threads on my phone but am on computer now so will check them out. sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Emporio ER432 with MainVue / Henley 40Feb 22, 2015 7:27 pm sassid Glad the electrical appointment went well for you. When we renovated our last kitchen we got the steam oven, the only thing we are not replicating from our previous kitchen is the coffee machine. Steam ovens are great - you can also get combi ovens which mix steam with regular oven, but I like the straight steam oven. Have definately missed it while we are renting... We haven't put in the little stair lights either. For some reason they don't really appeal to me? Yeah aesthetically I'm not fussed, just worried about the kids if they need to go downstairs at night. Trouble is that 4 of them will set you back close to $800. No issue for adults as the light on the wall of the staircase has a 2 way switch. Sometimes the problem is that we (should say "I") just over think these things. ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 11659 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 111063 |
