Browse Forums Building A New House Re: Building the Sahara Q3 with Henley 1362Sep 02, 2015 6:57 pm We've got the same one Izzy and until NHP this was very shaky..not sure if the SS has been able to do anything to fix it.. I'm sure you'll be fine as you have undermount sinks..anyone else having problems with this being wobbly ? Our Build Thread - http://forum.homeone.com.au/viewtopic.php?f=31&t=76750 Build thread of our Monaco Lux Q1 - https://forum.homeone.com.au/viewtopic.php?f=31&t=76750 Update: Handover - 2 Sep Re: Building the Sahara Q3 with Henley 1363Sep 02, 2015 7:40 pm Izzyb nestaxu Izzyb [quote="Neth04"]These issues have been identified by an independent inspector, is it? May I ask how much you paid them for each of these stages? [/quote] Catching up on your thread!! Loving the detailed inspection report and think you made up my mind to get Darbecca as my inspectors..in regards to these issue when Darbecca did the lock up stage..were they not identified then or some of these items haven't been done during that stage ie flashing, bricks/mortar issue.. Building the Sahara Q3 with Henley 1364Sep 02, 2015 8:22 pm I have that tap too, it does splatter everywhere, drives me nuts. I only got it temporarily until I bought a nice looking pull out mixer with veggie spray. There was only one to choose from at Cosham and it was old-school. The tap does look good though, just not functional. If your tap is wobbly probs not installed that good or maybe hole is too big? I don't think mine wobbles - will check it out when I get home. This is the pull-out tap that I had picked with PD. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And this tap I bought for our last house from grays online for about $70, veggie spray was not very strong but looks nice. I am after a squarer looking one now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The pull out mixer that Henley have is the same as the one we selected for our Metricon house 10 years ago! sassid ...building the Emporio with MainVue/Henley BLOG: http://thewaldorfproject.blogspot.com.au/ HOMEONE THREAD : https://forum.homeone.com.au/viewtopic.php?f=31&t=75753 Re: Building the Sahara Q3 with Henley 1365Sep 02, 2015 9:58 pm We have same tap Izzyb, and no issues at all. might be something to do with small plastic thingy inside the tip? Re: Building the Sahara Q3 with Henley 1366Sep 02, 2015 10:07 pm We got the same one and it splatters everywhere as well... Water is everywhere ... Even on the floor. Will try this controlling the stream thingy and see how it goes. Building Monaco Q2 with Henley in Wollert Re: Building the Sahara Q3 with Henley 1367Sep 03, 2015 6:27 am PEARZ We have a square version at work and its the worst thing ever, it splatters and makes the biggest mess! But it does look good though! Re: Building the Sahara Q3 with Henley 1368Sep 03, 2015 6:27 am Dreamz9 We got the same one and it splatters everywhere as well... Water is everywhere ... Even on the floor. Will try this controlling the stream thingy and see how it goes. Re: Building the Sahara Q3 with Henley 1369Sep 03, 2015 6:29 am mirz We have same tap Izzyb, and no issues at all. might be something to do with small plastic thingy inside the tip? Re: Building the Sahara Q3 with Henley 1370Sep 03, 2015 6:31 am evec I have the same Izzy, try to control the stream under the sink. Ours doesn't splatter anymore Building the Sahara Q3 with Henley 1371Sep 03, 2015 6:33 am TiVeena Izzyb nestaxu [quote="Izzyb"][quote="Neth04"]These issues have been identified by an independent inspector, is it? May I ask how much you paid them for each of these stages? Catching up on your thread!! Loving the detailed inspection report and think you made up my mind to get Darbecca as my inspectors..in regards to these issue when Darbecca did the lock up stage..were they not identified then or some of these items haven't been done during that stage ie flashing, bricks/mortar issue.. Re: Building the Sahara Q3 with Henley 1373Sep 03, 2015 7:59 am Thanks so much if it worked for you it should work for us! Re: Building the Sahara Q3 with Henley 1375Sep 03, 2015 11:12 am Izzyb TiVeena Izzyb [quote="nestaxu"][quote="Izzyb"][quote="Neth04"]These issues have been identified by an independent inspector, is it? May I ask how much you paid them for each of these stages? Catching up on your thread!! Loving the detailed inspection report and think you made up my mind to get Darbecca as my inspectors..in regards to these issue when Darbecca did the lock up stage..were they not identified then or some of these items haven't been done during that stage ie flashing, bricks/mortar issue.. [/quote] Ok..I might keep this in mind and either check early particularly there is so much issue with mortar and brick etc..if issues are find early it can hopefully can rectify early.. Building the Sahara Q3 with Henley 1376Sep 03, 2015 2:36 pm TiVeena Izzyb TiVeena [quote="Izzyb"][quote="nestaxu"][quote="Izzyb"][quote="Neth04"]These issues have been identified by an independent inspector, is it? May I ask how much you paid them for each of these stages? Catching up on your thread!! Loving the detailed inspection report and think you made up my mind to get Darbecca as my inspectors..in regards to these issue when Darbecca did the lock up stage..were they not identified then or some of these items haven't been done during that stage ie flashing, bricks/mortar issue.. Ok..I might keep this in mind and either check early particularly there is so much issue with mortar and brick etc..if issues are find early it can hopefully can rectify early.. Re: Building the Sahara Q3 with Henley 1377Sep 03, 2015 5:34 pm Did turning the knob work izzy?? We chose that tap for kitchen, butlers and laundry!!! She did tell us it splatters..... I thought if it was that bad they wouldn't use them. I was obviously wrong Re: Building the Sahara Q3 with Henley 1378Sep 03, 2015 10:36 pm Have been following your build dor a while now - it looks great! That floor looks amazing - which one is it? Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building the Sahara Q3 with Henley 1379Sep 04, 2015 1:51 am Hi Izzy How did your builder fix the brick overhang for you please? Izzyb 3. The brick over hang to the dwelling needs to be supported. The BCA, part 3.2.2.7 calls for a maximum overhang of 15 mm. several areas Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ exceed this allowance. All must be reworked and supported in accordance with AS 2870 prior to handover. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building the Sahara Q3 with Henley 1380Sep 04, 2015 8:04 am thanks Drew our floor is timber top kempas it's got it's own shine and this floor Darkens over time as well Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10506 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110570 |
