Browse Forums Building A New House Building the Sahara Q3 with Henley 1001Aug 04, 2015 7:31 pm Building the Sahara Q3 with Henley 1003Aug 04, 2015 7:34 pm Re: Building the Sahara Q3 with Henley 1004Aug 04, 2015 7:43 pm Re: Building the Sahara Q3 with Henley 1005Aug 04, 2015 7:44 pm Building the Sahara Q3 with Henley 1006Aug 04, 2015 7:46 pm the soaker pressure flashings to the dwellings walls have not been secured at 100 mm centres. the Plumbing Commissions Web Site, Technical Bulletin 0.03. clearly mandates that the flashings cannot be installed as per the installation on site, but rather must also have fastened at 100 mm centres. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building the Sahara Q3 with Henley 1008Aug 04, 2015 7:51 pm Re: Building the Sahara Q3 with Henley 1009Aug 04, 2015 7:52 pm Re: Building the Sahara Q3 with Henley 1010Aug 04, 2015 7:55 pm Re: Building the Sahara Q3 with Henley 1011Aug 04, 2015 7:56 pm Re: Building the Sahara Q3 with Henley 1013Aug 04, 2015 7:59 pm The colour bond gutter to the dwelling has been damaged during construction. There are a large amount of areas that have been scratched; over painted/stained and a large amount of areas have render smears. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ BlueScope Steel does not recommend the use of touch up paints on COLORBOND steel. The manufacturing process that gives COLORBOND steel its colour and gloss retention properties means that the surface weathers differently to air drying paint. After weathering, the areas which have been touched up will look different and can leave a blotchy look. Damaged areas will need to be replaced. Building the Sahara Q3 with Henley 1015Aug 04, 2015 8:01 pm The gaps between the architraves and the plaster above and below some windows and above all external wall located door frames must all be filled with suitable gap filler that is neatly applied. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The current gapping is allowing a volume of air to enter the dwelling. I refer the builder to the BCA, Part 3.12.3.3 and Part 3.12.3.5 which calls for all gaps around windows and doors to be sealed. AS 2047 also calls for the sealing of window to stop air penetration. Re: Building the Sahara Q3 with Henley 1017Aug 04, 2015 8:05 pm an out of square skirting that exceeded the allowance of 4 mm tolerance over 2.0m. Like ⋅ 2 comments ⋅ Pin to Ideaboard ⋅ the acceptable allowance is 4 mm over 2 m. This out of square skirting originates from the bowed plaster wall that it is fixed to, and as a result both the plaster wall and skirting will require reworking to straight. Re: Building the Sahara Q3 with Henley 1018Aug 04, 2015 8:06 pm Re: Building the Sahara Q3 with Henley 1019Aug 04, 2015 8:10 pm Entry/Garage/Laundry – the pedestrian access doorframe has not been installed with full perimeter door seals Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ 1 comment ⋅ Pin to Ideaboard ⋅ The garage to house entry door must have full weather seals fitted to comply with the BCA, part 3.12.3.3. This door is classed as an external door in the BCA as it separates an air-conditioned environment (Class 1) with the external environment (Class 10). The builder may claim that this is not required due to the energy report not stipulating its requirement. Re: Building the Sahara Q3 with Henley 1020Aug 04, 2015 8:12 pm Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 11084 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110809 |
