Browse Forums Building A New House 1 Feb 02, 2015 11:25 am I've just finished reading this very interesting article on Matt Cornell's site regarding the problems you might encounter if you have a small allotment. I'm sure he won't mind if I post the link: https://www.cornellengineers.com.au/pro ... #more-1733 Our allotment size was over 450 square metres - 476 square metres to be exact, but we have still run into problems because no notice was taken of the ground level and floor level of a neighbouring building. Re: Problems with small allotments 2Feb 02, 2015 2:16 pm Interesting article. I'm building a 16 sq house on a 294m2 lot (28x10.5m), so I guess I count as a small allotment. There weren't many bigger lots available in my estate unless you wanted a corner or uneven block (there are a few 12.5 frontages, but that was the largest in the releases so far). I'm a bit worried about my neighbor who will only have 8.5m frontage. I did look at house plans for this size but they were awful, you had to build on the boundary on both sides of the house so very few windows. Thankfully I will only have my garage on the fence line. It was worth the extra $12,000.00 or so for the bigger lot, plus I think my house is not too big for the land. I can't imagine someone putting a double story on a lot my size or smaller, but apparently it will happen. Hopefully they are well built and are safe! I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though.... 2 6679 Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they… 0 2771 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 2177 |
