Browse Forums Building A New House 1 Jan 25, 2015 7:48 am Can anyone clarify side set backs please? So the council rules are NSW you can have 900mm up to 4.5m high and then 900mm plus 1/4 above 4.5m high. Our block 500m2 single story, our home plan shows approx 4.8m high. Again shows approx 4.8high so it could go over or under?! What will our minimum side set back be? I am wondering if a roof can be made shorter to meet 4.5m requirement so we can have 1m on one side? We were originally told we would have 1m but when the plans were drawn up they changed to 1.5m as the house is just over 4.5m high. I really want 1m on one side. I am currently waiting on a reply from our builder but trying to also do my own research. Re: Side setbacks 2Jan 25, 2015 9:49 am It really depends on which council you are in as they all differ as opposed to a blanket NSW policy. Generally they look at the walls only being 900mm minimum not the roof or any other projections but you are also limited to 675mm from the boundary for those anyway meaning you'd have a narrow eaves. I think that is in keeping with BCA rules regarding fire separation between buildings. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ When you say 4.8m high are you talking just the outside walls or total roof height? They are two different things. Stewie Re: Side setbacks 3Jan 25, 2015 10:00 am Hi Stewie, thanks for the info. 4.8m is the overall height from top of roof to floor, I believe for every 1m over 4.5m it's 1/4 of 900mm. So 4.8m will be 1260mm? I am not sure if I am reading this right.. if this is the case I wonder if the roof can be made 300mm shorter to comply with 4.5m rules? My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6936 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12290 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20908 |
