Browse Forums Building A New House 1 Jan 14, 2015 8:57 am Hi I have an urgent decision to make about the height of the dropper head shower i am having in my main shower, my ceilings are 2.6m Here is the shower head. http://novelli.net.au/product.asp?brand ... uctID=1520 However, the shower screens from the floor are 2m Plan - https://www.dropbox.com/s/1efcv8cqy18ex ... d.JPG?dl=0 Should i have this lowered? as i know a rainfall head works a bit different. Re: Dropper shower head height from roof to shower? 2Jan 14, 2015 9:57 am For rainfall you want the shower head higher. I have got a gap of about 400mm between the shower head and the screen. The manufacturer should be able to tell you how far the water fans out beyond which it falls down. Re: Dropper shower head height from roof to shower? 3Jan 14, 2015 11:35 am We were in the same situation and switched from a 300mm shower arm to a 600mm shower arm. I was worried about overspray and aesthetics. Our shower is not installed yet so I can't comment on the end result unfortunately, but this is what it is to look like: I guess it also depends on the height of the people showering. My partner is six foot so there should be about a 30cm gap between his head and the rainhead. I am shorter. This website: http://annieocarroll.com/how-to/what-is ... ower-head/ recommends a 1 foot gap, so 30cm) between the rainhead and the top of the tallest person's head. Don't know if this helps at all! Building in Eliza Ponds, Spearwood I talk about my community here: https://www.facebook.com/22suburbs I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9570 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17540 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7755 |
