Hi people
This is in relation to double brick/WA build.
Just wondering if people considered or chose to install the electrical cabling for internal leaf brick walls, into conduits so that extra cabling could be fed through late? For example, to add a fan later and to avoid having the fan control panel put on a cavity wall where the cable could be easily fed through? Or perhaps installing an alarm and wanting the alarm panel on the same wall as front door light switches etc?
If you did add conduits for your inner wall cabling, is anyone able to recall what rough cost it was per conduit, or as a % over your electrical costs?
Iām awaiting a quote from my builder for about 7 internal brick wall locations incase I want to install a fan, or an alarm after handover.
thanks!
