Browse Forums Building A New House 1 Dec 18, 2014 3:19 pm Hi all, After years of saving, I finally bit the bullet and purchased some land in June 2014 and commenced construction of a house in November 2014. This is the timeline so far: 25 June 2014 - signed contract to purchase 794m2 block of land in Proserpine, QLD (S class site) 25 July 2014 - land settled August 2014 - contacted various builders, settled on Moloko Homes 2 October 2014 - signed Preliminary Agreement with Moloko Homes 3 November 2014 - final plans accepted after 3 drafts 11 November 2014 - signed contract with Moloko Homes 17 November 2014 - site scrape completed 24 November 2014 - footings completed 2 December 2014 - slab (raft slab) poured 10 December 2014 - block work completed 15 December 2014 - solid fill to blockwork completed, lintels in place ready for trusses This is the final floor plan I settled on, quite a few changes from their standard "Glouster" design. Total floor space - 243.15m2 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Floor Plan by Dale Mengel, on Flickr Slab down - 2 December 2014 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 20141202_171358 (2) by Dale Mengel, on Flickr Block work complete and solid filled - 15 December 2014 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 20141215_132021 (2) by Dale Mengel, on Flickr Dale - Building Newbie Proserpine, QLD Re: Whitsundays, QLD First time Build 2Dec 18, 2014 3:33 pm Standard Inclusions (not entire list of inclusions): Full termite barrier (Thithor) 2x external brass taps Conventional slab based on M class site Solid filled block work 10mm cement render Colorbond roofing (medium or light range) Air cell reflective foil insulation 3 coats internal paint 2 coats external paint (medium or light range) 2600mm ceiling height Tiling to entry, meals, kitchen, family, hallways, porch and alfresco areas Feature tile to shower and vanity Carpet to bedrooms/multi-purpose Stone bench tops (20mm) to kitchen and bathroom Soft closing drawers and doors Westinghouse 600mm fan-forced oven Westinghouse 600mm ceramic electric cooktop (decided against gas, which was standard) Westinghouse 600mm slideout rangehood Dishlex stainless steel dishwasher LED downlights throughout 2x TV points Split system air-con to master and living Ceiling fans in all rooms Driveway TV Antenna Wall mount clothes line Remote roller garage door All council fees, power, sewerage, water connections, etc C2 cyclone rated house, with additional cyclone bolts UPGRADES: Thermann evacuated tube solar hot water system (ground mounted tank) R2 batts to living areas (in addition to the standard air cell reflective foil) Added extra external tap water point to fridge space 2x ceiling fans to alfresco Added a few extra power points and TV points Fencing, with double access gate and single access gate Increased alfresco, secondary bedrooms floor space. Added secondary entry/exit point Dimmers to alfresco and living area lights After handover: All landscaping Dale - Building Newbie Proserpine, QLD Re: Whitsundays, QLD First time Build 3Dec 26, 2014 8:15 am Liking your house, love the alfresco area such a good size can imagine alot of entertaining happening there. When are you expecting completion? Building a sekisui house in Holmesville NSW viewtopic.php?f=31&t=75060 Re: Whitsundays, QLD First time Build 4Dec 26, 2014 12:32 pm Hopefully around late February or early/mid March. All depends when the big wet hits (if it does). The roof should be on by mid to late January so hopefully the rain holds off until then! Dale - Building Newbie Proserpine, QLD A quick update, we didn't have site start before Easter. Summit can't seem to give me a day when they are scheduled to begin, so I'm left with a vague "within 10-20… 4 26738 Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 8933 9 24643 |
