Browse Forums Building A New House 1 Dec 10, 2014 10:18 pm Hi We are building a 27 square single story home and cant decide wether to go with 2590 ceilings or 2700mm. We save just over $2000 is we go with 2590mm. At the end of the day 2700mm is only 110mm bigger do you think it makes much of a difference at all? Building the Sheffield 25 + 2 sq Re: 2590 ceilings or 2700mm 2Dec 10, 2014 10:41 pm You would be surprised what a difference 110mm will make. A small amount of money to create a much nicer feel. [Edit: Advertising links removed by moderator] Re: 2590 ceilings or 2700mm 4Dec 10, 2014 11:16 pm Really do you think it is a noticeable difference and do you think it will add value at resale? Building the Sheffield 25 + 2 sq Re: 2590 ceilings or 2700mm 5Dec 10, 2014 11:18 pm I have all mine high except kids beds and wet areas . It does look nice to have the differnt heights . And I wasnt sure if small rooms would look odd with heigh ceilings . But looking back now and considering if we ever sell should of raised whole lot . And its so much cooler Re: 2590 ceilings or 2700mm 6Dec 10, 2014 11:20 pm The main living areas really make the difference. At least do these if your budget is getting stretched. [Edit: Advertising links removed by moderator] Re: 2590 ceilings or 2700mm 7Dec 20, 2014 9:59 am Thanks all again for all your replies we have decided on the 2700 high ceilings I should look great had a friend who regreted not doing here that high so I definately think we have made the right choice.... Thanks Building the Sheffield 25 + 2 sq Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39682 I was quoting framing timber sizes from Australian Standard AS1684.4 Table A13 for 2700mm wall heights Tile Roof, single storey. This Australian Standard doesn't refer to… 8 7323 |
