Browse Forums Building A New House 1 Dec 09, 2014 3:09 pm Hi What types of concreting I can use around my house? I am after a reliable good concreter to do concreting around my house. so before that I thought to get some general knowledge from you guys I just need some concreting around my house as it's very muddy and to give support to slab. (According to our builder our land is moving too) So which type of concrete I should ask for when I get quotes? Can anybody recommend good reliable neat concreter who do service in Plumpton 3335 area(Melbourne north west) any comment highly appreciated. Re: help to understand types of concrete! 2Dec 09, 2014 3:35 pm Have a read through the posts at this link for the sort of things you should be thinking about; http://www.anewhouse.com.au/category/co ... /concrete/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: help to understand types of concrete! 3Dec 09, 2014 3:44 pm bashworth Have a read through the posts at this link for the sort of things you should be thinking about; http://www.anewhouse.com.au/category/co ... /concrete/ Thanks I will check it out. Re: help to understand types of concrete! 4Dec 09, 2014 3:45 pm does plain concrete is a good choice for around house? I have got a quotation from a concreter. What do you think about it? CONCRETE PATHWAY Concrete Preperation to Area: 75MM Wide Boxing,Pin Drilling,Laying Roadbase,Compacting,Lay Reinforcment. Lighty Moisture area Supply and lay Cruched Rock Supply and Install Rioforcment Sl/F52 200mm x 200mm Supply and Install Plain Concrete 25mpa Quantity -50.00 Rate-$60.00 Amount – $3,000.00 Supply & Install Pipe and Grate Quantity1.00 Rate $75.00 Amount $75.00 Subtotal $3,075.00 GST (10.00%) $307.50 Total $3,382.50 Re: help to understand types of concrete! 5Dec 31, 2014 1:25 pm I thought regular concreting is around $45~$50 per sqm and colored is around $55 per sqm. Are you going with color concreting or plain one? Also don't forget to ask for chairs under the mesh. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12569 Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12462 |
