Browse Forums Building A New House Re: Coral Homes general build thread 5401Sep 16, 2016 12:05 pm Depends what underlay you chose they have a 5mm or 10mm foam or a 5mm or 10mm rubber Re: Coral Homes general build thread 5402Sep 16, 2016 1:14 pm I chose 10mm gold foam. It looks like a air cell type underlay, is that good ? Re: Coral Homes general build thread 5403Sep 16, 2016 1:33 pm It should be soft then is your carpet soft? Or is it woven Re: Coral Homes general build thread 5404Sep 16, 2016 3:20 pm Boundaries: We are not sure if fences are right on boundary or not, we are installing new fences. Also.. one side is not pegged out. So I got some quotes today. First quote to reinstate boundary lines is $1800! Was not prepared for a figure like that Can't help with Coral underlay as we owner supplied sorry. http://www.forum.homeone.com.au/viewtop ... 31&t=82452 Cheers, Tegan (& Josh) Marcoola 30 with CORAL HOMES 2016 SANDSTONE LAKES, NINGI Queensland Our Build Thread: viewtopic.php?f=31&t=82452 Coral Homes general build thread 5405Sep 16, 2016 7:17 pm teganandjosh Boundaries: We are not sure if fences are right on boundary or not, we are installing new fences. Also.. one side is not pegged out. So I got some quotes today. First quote to reinstate boundary lines is $1800! Was not prepared for a figure like that Can't help with Coral underlay as we owner supplied sorry. http://www.forum.homeone.com.au/viewtop ... 31&t=82452 We are in Newcastle but paid $500 for our front fence to get pegged out, it's 65m frontage. Re: Coral Homes general build thread 5406Sep 16, 2016 9:00 pm Hi all. We are in getting ready to build in Brisbane (Logan) and would like to have a look at Coral's range. Can anyone tell me who the supplier is and where is their display? Re: Coral Homes general build thread 5407Sep 16, 2016 9:02 pm Tamara1975 Hi all. We are in getting ready to build in Brisbane (Logan) and would like to have a look at Coral's range. Can anyone tell me who the supplier is and where is their display? There is a display home at ormeau ridge Gold Coast and rochedale Brisbane Alex & Darren's Manhattan 23 Ormeau Ridge Follow my build = viewtopic.php?t=80441 Re: Coral Homes general build thread 5408Sep 17, 2016 1:27 pm Tamara1975 Hi all. We are in getting ready to build in Brisbane (Logan) and would like to have a look at Coral's range. Can anyone tell me who the supplier is and where is their display? There is also a display at Upper Coomera and Pimpama if you wanted to go out further Re: Coral Homes general build thread 5409Sep 17, 2016 4:56 pm Tamara1975 Hi all. We are in getting ready to build in Brisbane (Logan) and would like to have a look at Coral's range. Can anyone tell me who the supplier is and where is their display? Hi tamara, yarrabilba have a couple there too. When i went out there in april they had the avoca 25 and another one, but i think the avoca was only there for a few more weeks. Avoca 25 in Gainsborough Greens Gold Coast viewtopic.php?f=31&t=81406 Re: Coral Homes general build thread 5410Sep 17, 2016 7:14 pm vonsta76 Tamara1975 Hi all. We are in getting ready to build in Brisbane (Logan) and would like to have a look at Coral's range. Can anyone tell me who the supplier is and where is their display? Hi tamara, yarrabilba have a couple there too. When i went out there in april they had the avoca 25 and another one, but i think the avoca was only there for a few more weeks. Avoca 25 in Gainsborough Greens Gold Coast viewtopic.php?f=31&t=81406 They have the Grange and Capri on display there now Re: Coral Homes general build thread 5411Sep 18, 2016 1:48 pm Can anyone confirm for me what is supplied for TV/Data as standard from Coral...(on the plans it has a Fibre Optic box in the garage...is this a Hills Home Hub type box?) We have NBN Package#1 in our Tender. I have added Data/Phone and TV Points around the house. In the media I have added data/phone data & tv pionts is this suitable for Foxtel, Do I even need a phone point in the media?Im so not up with the latest tech, any help appreciated, Thanks. Re: Coral Homes general build thread 5413Sep 18, 2016 8:17 pm marcoola Can anyone confirm for me what is supplied for TV/Data as standard from Coral...(on the plans it has a Fibre Optic box in the garage...is this a Hills Home Hub type box?) We have NBN Package#1 in our Tender. I have added Data/Phone and TV Points around the house. In the media I have added data/phone data & tv pionts is this suitable for Foxtel, Do I even need a phone point in the media?Im so not up with the latest tech, any help appreciated, Thanks. Hi Marcoola, The data contractors on my build supplied me with 1 phone port (CAT5e) and 1 data port (CAT6) from the garage (NBN) to a location in the house I specified. They have not started fitting the gyprock walls so I do not know what cabinet will be installed. NBN Package will just be a basic panel with provisions for the NBN lead in cable. I did not install a TV antenna as they are obsolete to me, but when I met with the electrical contractor, I mentioned Foxtel to them and they installed a couple of ports suitable for Foxtel. The ports go from wall to roof cavity. It takes wisdom to build a house, and understanding to set it on a firm foundation; It takes knowledge to furnish its rooms with fine furniture and beautiful draperies. Proverbs 24:3-4 Re: Coral Homes general build thread 5414Sep 18, 2016 8:29 pm budoy In addition to marcoola's post, if you have several data points (nbn), do you just run a switch from the very main port? Hello Budoy, The NBN NTD will have 4 ports for data and 2 ports for voice. I believe the voice ports are not used. If you are with Telstra your T-Gateway connects to one of the 4 data ports on the NBN NTD. Your T-Gateway has 4 gigabit ports to connect to the internet. If you need more ports you will need to connect a switch to one of these ports. Your phone handset connects to the phone port on the T-Gateway. It takes wisdom to build a house, and understanding to set it on a firm foundation; It takes knowledge to furnish its rooms with fine furniture and beautiful draperies. Proverbs 24:3-4 Re: Coral Homes general build thread 5415Sep 19, 2016 7:57 pm Square balusters? Since we have some time to kill...My husband has been going through variations and we've just come across a detail we had not noticed nor discussed. The assumption was that balusters are round. Obviously not the case. Has anyone noticed this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 5416Sep 19, 2016 8:19 pm Corallake- this is an item on colour selections form. Consultant should have shown you the range to choose from. Round are an option I believe. Is that your colour variation you posted ? Hang on I'll find mine C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Coral Homes general build thread 5417Sep 19, 2016 8:28 pm Hey! You got silver balustrades! I want them! I got timber Wanna swap? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the drawing Coral gave to the company Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Contact Allwood stairs and ask for the Coral rep. He should be able to change your handrail no dramas C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Coral Homes general build thread 5418Sep 19, 2016 9:07 pm MrsJM Corallake- this is an item on colour selections form. Consultant should have shown you the range to choose from. Round are an option I believe. Is that your colour variation you posted ? Hang on I'll find mine C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 5419Sep 19, 2016 9:09 pm I'm referring to the vertical thingys...budget wouldn't allow for glass panels. I've never even seen the square profile. At the meeting we assumed they would have a round profile because that was the only option on the form. Strange. Masterton do stainless handrails. I went to Homeworld 2 and saw them. Nice! Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 5420Sep 20, 2016 7:32 am Ohh sorry yes... Hmm. I would have thought you could vary it. Perhaps worth a call directly to the company to see if you can change direct with them. Silver will be so beautiful though, round or square C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 You should check your detail drawings, it may show downpipe within brick pier. 14 14303 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 14409 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4381 |
