That's awesome!!! So happy for you and the whole family. Finally out of cramped quarters to a brand new house.
Coral who????
Browse Forums Building A New House Re: Coral Homes general build thread 11021Jun 30, 2018 9:59 am Ryan2007 Hey coral lake we are in everything at handover was fine we have done well practically all moved in and we did it at night we were that keen 😀 That's awesome!!! So happy for you and the whole family. Finally out of cramped quarters to a brand new house. Coral who???? Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 11022Jun 30, 2018 7:34 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Some move in updated we are getting thre! Re: Coral Homes general build thread 11023Jul 02, 2018 10:25 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi coral ppl, in bed 4 the robe seem to have a slope to it. Apparently the roof is not quite level which has thrown out the measurements for the robe. This is the only place it is very visible? We met with our SS and he said it’s common and there’s not much they can do? That didn’t sit right and I felt pretty annoyed as you would see this in a display home! What would you guys do.. should I escalate it higher...? Is there some sort of quick fix and has anyone else had this issue since it’s common? Thanks 🙏 Coral Homes general build thread 11024Jul 02, 2018 3:24 pm mj-mac4 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi coral ppl, in bed 4 the robe seem to have a slope to it. Apparently the roof is not quite level which has thrown out the measurements for the robe. This is the only place it is very visible? We met with our SS and he said it’s common and there’s not much they can do? That didn’t sit right and I felt pretty annoyed as you would see this in a display home! What would you guys do.. should I escalate it higher...? Is there some sort of quick fix and has anyone else had this issue since it’s common? Thanks http://www.vba.vic.gov.au/__data/assets ... s-2007.pdf Have a look at section 9. 4mm deviation over 2 metres is the upper tolerance. That photo you took looks way more than tolerance. Sounds like your SS is trying to wiggle out of it. Don’t let him. Re: Coral Homes general build thread 11025Jul 02, 2018 3:35 pm kirashogun mj-mac4 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi coral ppl, in bed 4 the robe seem to have a slope to it. Apparently the roof is not quite level which has thrown out the measurements for the robe. This is the only place it is very visible? We met with our SS and he said it’s common and there’s not much they can do? That didn’t sit right and I felt pretty annoyed as you would see this in a display home! What would you guys do.. should I escalate it higher...? Is there some sort of quick fix and has anyone else had this issue since it’s common? Thanks http://www.vba.vic.gov.au/__data/assets ... s-2007.pdf Have a look at section 9. 4mm deviation over 2 metres is the upper tolerance. That photo you took looks way more than tolerance. Sounds like your SS is trying to wiggle out of it. Don’t let him. Make sure you put this in writing and send it to the SS, the CSO, the AM, State manager and National Manager. Do it now! Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 11026Jul 02, 2018 5:55 pm kirashogun mj-mac4 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi coral ppl, in bed 4 the robe seem to have a slope to it. Apparently the roof is not quite level which has thrown out the measurements for the robe. This is the only place it is very visible? We met with our SS and he said it’s common and there’s not much they can do? That didn’t sit right and I felt pretty annoyed as you would see this in a display home! What would you guys do.. should I escalate it higher...? Is there some sort of quick fix and has anyone else had this issue since it’s common? Thanks http://www.vba.vic.gov.au/__data/assets ... s-2007.pdf Have a look at section 9. 4mm deviation over 2 metres is the upper tolerance. That photo you took looks way more than tolerance. Sounds like your SS is trying to wiggle out of it. Don’t let him. Thankyou so much Kira! This was very helpful. Good to know we’re arent just being picky but it’s definitely not up to standard. 😊 Re: Coral Homes general build thread 11027Jul 02, 2018 5:55 pm Corallake kirashogun mj-mac4 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi coral ppl, in bed 4 the robe seem to have a slope to it. Apparently the roof is not quite level which has thrown out the measurements for the robe. This is the only place it is very visible? We met with our SS and he said it’s common and there’s not much they can do? That didn’t sit right and I felt pretty annoyed as you would see this in a display home! What would you guys do.. should I escalate it higher...? Is there some sort of quick fix and has anyone else had this issue since it’s common? Thanks http://www.vba.vic.gov.au/__data/assets ... s-2007.pdf Have a look at section 9. 4mm deviation over 2 metres is the upper tolerance. That photo you took looks way more than tolerance. Sounds like your SS is trying to wiggle out of it. Don’t let him. Make sure you put this in writing and send it to the SS, the CSO, the AM, State manager and National Manager. Do it now! Thankyou corallake, I will sending emails tonight. Thanks for your advise 😊 Re: Coral Homes general build thread 11028Jul 02, 2018 7:54 pm Ryan2007 Hey coral lake we are in everything at handover was fine we have done well practically all moved in and we did it at night we were that keen Oh yaay so happy for you Re: Coral Homes general build thread 11029Jul 02, 2018 7:55 pm Ryan2007 Hey coral lake we are in everything at handover was fine we have done well practically all moved in and we did it at night we were that keen Ps did DA give you a welcome gift? just wonder g if he's stock piling as still nothing for us Re: Coral Homes general build thread 11030Jul 03, 2018 7:49 am mj-mac4 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi coral ppl, in bed 4 the robe seem to have a slope to it. Apparently the roof is not quite level which has thrown out the measurements for the robe. This is the only place it is very visible? We met with our SS and he said it’s common and there’s not much they can do? That didn’t sit right and I felt pretty annoyed as you would see this in a display home! What would you guys do.. should I escalate it higher...? Is there some sort of quick fix and has anyone else had this issue since it’s common? Thanks 🙏 I saw someone else's thread a while back and when they did their blinds, they realised that there was a slope as well. I am going to check mine today when I have a look. Re: Coral Homes general build thread 11031Jul 04, 2018 3:20 pm Hi all Can someone please tell me how much the credit was for removing their 60cm ceramic cooktop. I am wanting to buy an induction myself and get them to install it. The other option originally was see how the cooktop goes then replace, but with the stone bench tops this may be a problem? Re: Coral Homes general build thread 11032Jul 05, 2018 11:17 am Hey coral ppl, has anyone paid the tiler a cashie for going from 2.1 to ceiling height. We have got the elegance inclusions and thought we would get a price from the tiler. He quoted us $500 for labour work for bathroom, toilet and ensuite. The extra tiles we are paying for through beaumounts. do you guys think $500 is a resonable price for labour? I’m not sure if you his is cheap or not??? Help please thanks 🙏 Re: Coral Homes general build thread 11033Jul 06, 2018 5:27 am georgiarosedale Hi all Can someone please tell me how much the credit was for removing their 60cm ceramic cooktop. I am wanting to buy an induction myself and get them to install it. The other option originally was see how the cooktop goes then replace, but with the stone bench tops this may be a problem? Only about $220 from memory. I deleted all appliances and got about $600 back in total M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Coral Homes general build thread 11034Jul 08, 2018 4:16 pm Hey all, do you guys have a lot of movement in your cavity slider walls? The one in oure suite literally moves a lot if you rest up against it. And seems very fragile. I’m worried Becoz this wall is going to be tiled to the ceiling. Hence the grout and tiles may eventually crack. Does anyone else have this issue when in building faze? Thanks 🙏 Re: Coral Homes general build thread 11035Jul 08, 2018 4:30 pm mj-mac4 Hey all, do you guys have a lot of movement in your cavity slider walls? The one in oure suite literally moves a lot if you rest up against it. And seems very fragile. I’m worried Becoz this wall is going to be tiled to the ceiling. Hence the grout and tiles may eventually crack. Does anyone else have this issue when in building faze? Thanks 🙏 I will check tomorrow and let you know. Re: Coral Homes general build thread 11036Jul 08, 2018 5:18 pm mj-mac4 Hey all, do you guys have a lot of movement in your cavity slider walls? The one in oure suite literally moves a lot if you rest up against it. And seems very fragile. I’m worried Becoz this wall is going to be tiled to the ceiling. Hence the grout and tiles may eventually crack. Does anyone else have this issue when in building faze? Thanks Where about a do you mean movement? Post handover and mine is a pain in the backside. Even the hint of a breeze and if the door is closed it just bangs non stop. They have tried to fix it to no avail. It’s like torture treatment! M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Coral Homes general build thread 11037Jul 08, 2018 8:16 pm MrsJM mj-mac4 Hey all, do you guys have a lot of movement in your cavity slider walls? The one in oure suite literally moves a lot if you rest up against it. And seems very fragile. I’m worried Becoz this wall is going to be tiled to the ceiling. Hence the grout and tiles may eventually crack. Does anyone else have this issue when in building faze? Thanks Where about a do you mean movement? Post handover and mine is a pain in the backside. Even the hint of a breeze and if the door is closed it just bangs non stop. They have tried to fix it to no avail. It’s like torture treatment! Oh no! I’m seriously thinking to get them to change it back to standard door frame. It’s so wonky. Totally not the standard I expected. If you grab the wall and try and move it the whole wall wobbles. 😳 Re: Coral Homes general build thread 11038Jul 08, 2018 8:19 pm bestspecials mj-mac4 Hey all, do you guys have a lot of movement in your cavity slider walls? The one in oure suite literally moves a lot if you rest up against it. And seems very fragile. I’m worried Becoz this wall is going to be tiled to the ceiling. Hence the grout and tiles may eventually crack. Does anyone else have this issue when in building faze? Thanks 🙏 I will check tomorrow and let you know. Thanks best specials! Also do you have pop up drains in your bathroom and ensuite sinks. The ones delivered are just standard with a big ugly plastic plug. But our elegance inclusions state pop up chrome drains for the sinks. I just checked our contract. Could you please post a pic of your bathroom sinks so I can see please. Only if you have time. Thanks 🙏 Re: Coral Homes general build thread 11039Jul 08, 2018 8:28 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the crappy trap/ drain they have supplied us with for our bathrooms and ensuite. We have paid to have elegance inclusions. They totally try to get away with these cheap ones yet our contract says chrome pop up traps for our bathroom and ensuite sinks. I just checked our contract. Check what you getting ppl.. We have paid for it so we should get it. Coral are so dodge 😕 You should check your detail drawings, it may show downpipe within brick pier. 14 14124 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13781 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4358 |
