Browse Forums Building A New House 1 Dec 02, 2014 10:29 pm Hi, I have a builder in Adelaide telling me their slab requirements/costs will be lower due to the lightweight cladding used (Primeline weatherboard with some Hebel) as apposed to brick veneer. I'm in the north east and expect H2 soil (that's what the neighbor has). Does this sound right? Has anyone heard similar claims? Thanks Re: Slab requirements for lightweight cladding 2Dec 03, 2014 5:04 am Your slab costs will be mainly determined by soil report and site condition rather than whether walls are BV or light cladding. Overall there is insufficient difference to foundation loading in single storey construction whichever cladding system you use. I think your builder is having you on Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Slab requirements for lightweight cladding 3Dec 03, 2014 11:56 am I think there would be some savings - but it would be pretty minimal. Small footprint in Eliza Ponds, Spearwood WA Re: Slab requirements for lightweight cladding 5Dec 04, 2014 8:53 am building-expert .....rather than whether walls are BV or light cladding. Overall there is insufficient difference to foundation loading in single storey construction whichever cladding system you use. If that's the case then why does the Australian Standard for slabs/footings specify different footing depths depending on building material (clad, BV, full brick, etc)? I would have thought the deeper the footing, the more time required to prepare (not a lot), heavy gauge or more reinforcing and of course, more concrete. These things do impact the cost of the foundations. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3640 I'm wondering if anyone knows what the requirements are of a builder to be eligible to hold Domestic Building Insurance for proposed works. https://www.dbi.vmia.vic.gov.au… 0 3323 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12001 |
