Browse Forums Building A New House 1 Nov 27, 2014 1:08 am Hi all, we are sorting our pre-start out at the moment and have decided that we will supply our own kitchen appliances after handover, which is fine with the builder, they said they just need the measurements of the appliances to leave the required space. The only issue I had was if they stuff something up with the measurements and our appliances don't fit who is responsible? Pre-start lady said we are (might have been miss communication?), but then a sales rep from good guys said that if we require the builder to leave a certain space and they stuff it up, they have to fix it. Sounds logical to me, the only case I could imagine it would be our responsibility is if we give the wrong measurements or decide on different appliances in a different size. But as long as we provide the correct measurements for fitting it shouldn't be a problem should it? Any insights to that would be much appreciated. Cheers Re: requests to the builder 2Nov 27, 2014 4:43 am The buider is responsible for building to the agreed drawings so make sure the construction drawings you sign have the correct dimensions. Might be best to make the dimensions say 10-15mm bigger once everything is built you can infill spaces but you can't make something bigger. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20417 Hi, did you get any money from insurance? if you did, does it match what you've already paid the builders? 3 9565 |
