Browse Forums Building A New House Re: No shower drain in the slab 4Jun 11, 2008 9:32 pm It would be normal for the slab to be boxed out roughly 300 square where the trap will go. The pipe is often covered, but it would be unusual not to pick the location.
I'd check to see that the supervisor follows through & checks with the plumber. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 3565 Agreed. I just found out today the certifier has not given the final sign off. 2 3131 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 6343 |
