Browse Forums Building A New House Re: Banksia Grove - Soakwell 2Dec 08, 2014 9:07 pm City of wanneroo does not allow stormwater to enter their drains. It is a requirement for you to contain the stormwater on your block (meaning it cannot disperse to your neighbour or onto the street.). You need to install soak wells that will allow the stormwater to drain into the sand on your block. Make sure you keep the, at least 1.5m -2.0m away from the footings of the home. [Edit: Advertising links removed by moderator] One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 679 |
