Browse Forums Building A New House 1 Jun 10, 2008 11:47 am Hi All,
New to this forum, but have been reading posts for a little while. Looking at building a custom house in the eastern suburbs of Melbourne. We have had our plans drawn up and the house including garage and alfresco is approx. 39 (imperial) squares. I have been told that the price per square for a mid-range quality custom home is around 10 - 12K per square. Is this price per square factor based on total squares of a plan or living squares. ie. living squares are approximately 32, garage and alfresco approx. 7 squares. This makes a big difference to the budget we need to set aside. Any feedback is greatly appreciated. Re: Price per Square? 2Jun 11, 2008 9:42 am Hi Radiuz, In my short experience some companies charge per sq and some don't, I've called a few custom builders and ask how they price the house, and they didn't give me a concrete answer, and say it depends on many factors. We are most likely building with National Builders and they charge per square, but I guess it also depends on the difficulty and shape of the house/walls etc.
Best thing to do is call a few customer builders and see what they say, and correct me if I am wrong, but Alfresco and Garage is usually included in the price as its under the roofline and its a part of your Slab. Good luck and let us know how u go. Re: Price per Square? 3Jun 11, 2008 10:05 am Hi radiuz,
When I was looking at building a custom home, the price was in total. When I questioned why it was the same price to build a garage as the kitchen, I was told that it all balances itself out. With the quote for 10-12K I would be very aware that this only covers basic prices for everything. If you choose a more expensive tile than the allowance it will bump your price up - the same with appliances and carpets etc. You will find they will be more flexiable than volume builders, and if you go under budget on something you actually get the money back!! Paula 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 No idea about the driveway question, but your price for a house that size including landscaping seems very good! 1 6161 Wow I hadn't realised things had gotten that pricey in just a couple of years since I built, that is crazy with how much land is now costing if you aren't lucky enough to… 3 7126 |
