Browse Forums Building A New House 1 Oct 17, 2014 9:35 pm Hi all. Went and inspected work so far and found a hole had been bashed through the fast brick on our bedroom wall. After closer inspection we found a thin ( 4mm) wire rope that is positioned down the cavity out the hole and up our bedroom wall. This is attached to where the steel beam sits on the brick work. The wire rope isn't hard up against the wall and protrudes off the wall about 6mm. Either they're going to slap heaps of plaster on this wall or they're going to chase the wall and poke it in to the chase cavity. Has anyone else come across this practise of beam securing? Regards Ricky Re: Anchor wire down my bedroom wall 2Oct 20, 2014 11:14 pm Hi happyhouse, A little confused... is it a tie-down cable... and vertical? Have you a metal roof? If so its for wind resistance probably. A photo or two might help Leonardo_23 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8317 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16288 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10482 |
