Browse Forums Building A New House Re: Structural Engineer 2Oct 20, 2014 11:19 pm Hi vidy123, I'm not from Perth, but you need to visit at least 2 and ask how much. As to good structural engineers, they are all supposed to be good because if they aren't the house will fall down. If you are paranoid about the structure than you could get another engineer to check the documents when they are completed... used to be done for every job up till the early 1980's I believe... but that cost even more Leonardo_23 3 6403 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9687 |
