Browse Forums Building A New House 1 Oct 09, 2014 12:50 pm Hi, our house is just over 3 years old and the eaves look terrible - a lot of them look as though they weren't cut correctly so there are gaps ... I think a call to the builder is in order - what do others think? For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: How long should you expect your new eaves to look good? 2Oct 11, 2014 1:36 pm If you think it is unworkmanlike, then I say go and get it rectified... but I warn you that the builder's response will often be not satisfactory to you, with statements such as ... that's normal for a project house, it's standard and many more that I have come across. There is also The Guide to Standards and Tolerances to deal with and many think that is unfair too. Good luck... and you could have a close look at other things as well.. such as your tile pointing if you have a tiled roof. Is it peeling or separating or are the hip end tiles separating from each other. Then there's the garage ceiling if plasterboard for instance... is it undulating (shine torch across the ceiling to find out). And are there popped nails... and on it goes I can assure you, Cheers and good luck. Best to have a thorough look first though, based on experience Leonardo_23 Re: How long should you expect your new eaves to look good? 3Oct 11, 2014 3:39 pm Depends on how bad. If they are sagging or shrinking badly a call to builder might be in order - a nice one. But - like all things outside - you do need to look after things - and normal wear and tear occurs. I'd hope you'd get more than 3 years though ... Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5869 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7847 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 23401 |
