Browse Forums Building A New House 1 Jun 08, 2008 5:01 am Im getting ready to make two different spots for two different LVL's. I was told I only need 3" of surface area to set the LVL on. That seems like such a small amount. My question is that true ? I was going to make the area 5 1/2".
Thanks Re: LVL Question 6Jun 11, 2008 8:22 pm Depending upon the application laminated beams can bear on as little as 30mm.
part of 1001 facts . . . . . . Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 1 13125 |
